查看: 217|回复: 11
Someone please correct me if I'm wrong
 楼主| 发表于 2020-1-9 08:39:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"Aren't placarded or oversize loads supposed to enter open weigh stations even if given a green bypass signal?  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-9 08:47:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes. always.","replyToPid":0}
发表于 2020-1-9 19:59:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good thing we’re governed by the feds and every state gets to do what they want. Not confusing at all","replyToPid":0}
发表于 2020-1-9 10:43:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes it even states it on the signs to the port","replyToPid":0}
发表于 2020-1-9 09:36:42 来自手机 | 显示全部楼层
{"replyToPid":300659,"replyTo":"","text":"Partially Incorrect.\n\nIn regards to hazmat, only certain states require scaling regardless of  green bypass signal.\n\nArizona, Ohio (if unlicensed to carry hazmat), Arkansas, Idaho and Colorado (if using a temporary permanent).\n\nPlease double check."}
发表于 2020-1-9 12:05:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"certain states no most states yes I haul oversize constantly and last week Mississippi was a don't have to stop state just to name one","replyToPid":0}
发表于 2020-1-9 09:29:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"class 7 and class 1.1 1.2 1.4 plackards are a must","replyToPid":0}
发表于 2020-1-9 09:27:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"hazardous materials yes but basic placards no","replyToPid":0}
发表于 2020-1-9 09:27:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"it depends on the load","replyToPid":0}
发表于 2020-1-9 22:34:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"You see placard 7 and placards 1.1-1.4 are more critical to our environment at the same time a potential risk to humans so they require extreme attention as like common placards less of a environmental risk.","replyToPid":0}
GMT+8, 2026-2-16 15:20 , Processed in 0.068158 second(s), 24 queries .
