查看: 164|回复: 8
Its bad road bad weather season so a quick question without using Google or anything else but your knowledge
 楼主| 发表于 2020-1-9 08:38:28 来自手机 | 显示全部楼层 |阅读模式
{"text":"You are broken down on the side of the interstate how far apart do you place your EMERGENCY TRIANGLES behind your truck?  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-9 09:14:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"2-lane straight: 1 out front 10ft w/ 2 in the back at 10' & 100' from trailer.\n2-lane curve: 1 out front 10' after the curve w/ the back at 10' & 100' from trailer.\nDivided: from the driver side, 10', 100', & 200' going diagonally to the passenger side\nNo median multi-lane: same as what is said for 2-lane traffic.\n\nAll are presumed distances for the placement of the triangles (if parked on the shoulder off the travel lanes).","replyToPid":0}
发表于 2020-1-9 10:25:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I pretty sure this question was on the written test when you got your CDL. It was in my State. It is in the FMCSA safety book that all drivers are required to have a copy of in their truck.","replyToPid":0}
发表于 2020-1-9 08:48:49 来自手机 | 显示全部楼层
407746 发表于 2020-01-09 00:45:36 depends on what kind of roads are broken down on... are you on a straight stretch or Curves? and what's the speed limit? specify your question.
","text":"Don’t forget to mention, the proper angle they need to be placed at. WAY too many drivers set them up like they’re trying to guide traffic into the back end of their flippin’ trailer!!!","replyToPid":300656}
发表于 2020-1-9 08:45:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"depends on what kind of roads are broken down on... are you on a straight stretch or Curves? and what's the speed limit? specify your question.","replyToPid":0}
发表于 2020-1-9 11:20:22 来自手机 | 显示全部楼层
336899 发表于 2020-01-09 02:25:53 I pretty sure this question was on the written test when you got your CDL. It was in my State. It is in the FMCSA safety book that all drivers are required to have a copy of in their truck.
","text":"It was stated in the GA CDL test. ","replyToPid":300736}
发表于 2020-1-9 11:23:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why worry about triangles nobody pays attention to anyway most truck drivers never move over if they can ","replyToPid":0}
发表于 2020-1-10 04:09:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Place the 1st one on the last state border you crossed, place the 2nd one half way between, and throw the 3rd one in the ditch behind your truck on a 4 lane hwy ( in front  on 2 lane ) ","replyToPid":0}
发表于 2020-1-13 05:24:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"It is also on the inside of the triangle box top, allegedly.","replyToPid":0}
GMT+8, 2026-4-17 08:39 , Processed in 0.084044 second(s), 24 queries .
