查看: 83|回复: 2
2010 Volvo parking heater?
 楼主| 发表于 2019-1-24 21:50:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey I have a 2010 Volvo & it has a parking heater located under the bed. Can anyone break down for me what exactly this is for? As the owners manual doesn't explain much on it.","pics":"[]","canComment":true}
发表于 2019-4-7 15:19:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Parking heater? are you talking about the bunk heater?","replyToPid":0}
发表于 2019-4-7 20:02:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's a bunk heater and if it is factory installed it's controlled in the bunk area.  you have to press the menu button till it says \"heat\" then press the on/off button then press the set button! if you don't press the set button it will not work! also do not have the air inlet/supply vent covered or obstructed either cause that will prevent it from working.  use the button below the menu button (the one that is blue&red) to control the temp.","replyToPid":0}
GMT+8, 2026-2-4 12:15 , Processed in 0.065781 second(s), 23 queries .
