查看: 111|回复: 3
Hey guys. I have a 2016 cascadia. And the coolant won’t stop leaking. It’ll go about 4/5 hours and then I have to add.
 楼主| 发表于 2020-1-8 10:21:48 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-1-8 10:51:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I had a coolant leak a few months ago on the same truck with the DD15. It ended up being a coolant line about 6 inches in length at the back of the block near the firewall. TA mechanic says it’s a common problem and he replaced the plastic line with the updated rubber line. ","replyToPid":0}
发表于 2020-1-8 10:42:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Stop to TA or Petro, probably radiator messed up","replyToPid":0}
发表于 2020-1-8 10:48:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"any visible leaks?","replyToPid":0}
GMT+8, 2026-2-16 15:44 , Processed in 0.050287 second(s), 24 queries .
