查看: 174|回复: 10
Douchebag drivers blocking pumps and not fueling.
 楼主| 发表于 2020-1-8 00:23:30 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true,"externalShare":false}
发表于 2020-1-8 01:19:58 来自手机 | 显示全部楼层
688983 发表于 2020-01-07 16:36:36 Wow is your truck dirty . Disgusting \nDon't you ever wipe down the dashboard .
","text":"and he's got plenty of time to do so while he waits for fuel 🤷🏻‍♂️","replyToPid":299474}
发表于 2020-1-8 07:05:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"I pull their seals when they do that. Good luck delivering your load a hole","replyToPid":0}
发表于 2020-1-8 04:01:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Navajhoe","replyToPid":0}
发表于 2020-1-8 10:01:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"wait just a minute... I must be seeing things because you can clearly see the driver standing next to the Navajo truck?!?","replyToPid":0}
发表于 2020-1-8 01:34:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"I saw the same in Atlanta this morning, people literally left their truck in line and went inside then people in line outside had to wait for them to show back up. absolutely ridiculous","replyToPid":0}
发表于 2020-1-8 03:03:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Seen a guy take his 1/2hr break on the pump. \n\nsaw another one on a different day, same week go in with shower bag leavening truck on pump.","replyToPid":0}
 楼主| 发表于 2020-1-9 10:37:10 来自手机 | 显示全部楼层
553650 发表于 2020-01-08 02:01:47 wait just a minute... I must be seeing things because you can clearly see the driver standing next to the Navajo truck?!?
","text":"ya 30 minutes later. Still not fueling","replyToPid":299857}
发表于 2020-1-9 10:39:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"so......you got your truck cleaned? at least wiped down so it wasn't a sh**hole? and don't you have reverse to go to another pump?","replyToPid":0}
 楼主| 发表于 2020-1-9 10:47:52 来自手机 | 显示全部楼层
553650 发表于 2020-01-09 02:39:28 so......you got your truck cleaned? at least wiped down so it wasn't a sh**hole? and don't you have reverse to go to another pump?
","text":"Didn't get truck cleaned. Just gonna get a different one when I get back to yard. All the pumps were blocked.","replyToPid":300743}
GMT+8, 2026-2-16 15:19 , Processed in 0.064539 second(s), 24 queries .
