查看: 156|回复: 12
What are your thoughts about the Tesla Semi?
 楼主| 发表于 2020-1-7 11:26:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"How much they paying people to drive one?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":720.0,\"name\":\"\",\"url\":\"\",\"width\":960.0}]","canComment":true,"externalShare":false}
发表于 2020-1-8 06:17:03 来自手机 | 显示全部楼层
{"replyToPid":299329,"replyTo":"
664930 发表于 2020-01-07 08:39:03 not made for otr. complete otr failure. 25 degrees and model 3's have 30-40% range loss. this truck max range is 550 in perfect conditions. imagine just running out of battery because of being stuck in Wyoming or somewhere because of bad weather closing the road and you cant get to a station to charge your 300 mile range truck.
","text":"Stop dude. Watch this channel. https://www.youtube.com/user/bjornnyland. He runs EVs in Norway or Sweden when its 0°F. He does just fine. Also not being able to find a charging station isn’t a permanent issue. That will disappear after mass uptake (https://apps.apple.com/us/app/plugshare/id421788217). The Tesla semi already runs batteries and car parts from Sparks NV to the Bay and Hawthorne CA. They do just fine going up and over the Rockies fully loaded even in the winter, and even better on mileage than originally stated at unveiling. With an EV you don’t have to run an engine to power accessories like the HVAC and entertainment. The Tesla semi can run an AC unit or it’s heater from the gigantic batteries meaning you’ll get through a closed road just fine. Also you charge everyday so you’ll have plenty of charge. If you’re a smart driver you already plan ahead and know about the weather ahead. If you know a hurricane is coming through down south you’re gonna top off your tanks before getting close right? It’s going to do just fine. Tesla is making patents on new battery chemistry’s. So are other manufacturers. John Goodenough has a new glass battery he’s working on which has more energy density than ones today so the packs will have more power in the same space. "}
发表于 2020-1-7 17:00:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not to mention that the truck will start freaking out as soon as the sensors get clogged up by snow, ice, insects, etc","replyToPid":0}
发表于 2020-1-7 16:39:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"not made for otr. complete otr failure. 25 degrees and model 3's have 30-40% range loss. this truck max range is 550 in perfect conditions. imagine just running out of battery because of being stuck in Wyoming or somewhere because of bad weather closing the road and you cant get to a station to charge your 300 mile range truck.","replyToPid":0}
发表于 2020-1-8 16:26:28 来自手机 | 显示全部楼层
{"replyToPid":300065,"replyTo":"
884942 发表于 2020-01-08 05:44:44 I run through donner pass 5-8 times a week. i have never seen a Tesla truck run through there. I only saw a picture of one at the Truckee weight station.
","text":"Just because you can’t see them doesn’t mean they aren’t there. There’s 24 hrs in a day. You aren’t there all of them"}
发表于 2020-1-8 06:16:51 来自手机 | 显示全部楼层
310244 发表于 2020-01-07 10:15:48 It’s an electric truck, not an autonomous truck.
","text":"THANK YOU","replyToPid":299344}
发表于 2020-1-7 18:15:48 来自手机 | 显示全部楼层
884942 发表于 2020-01-07 09:00:47 Not to mention that the truck will start freaking out as soon as the sensors get clogged up by snow, ice, insects, etc
","text":"It’s an electric truck, not an autonomous truck.","replyToPid":299333}
发表于 2020-1-7 15:47:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only the engineers are driving them for now ","replyToPid":0}
发表于 2020-1-8 05:49:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Can’t wait for them to make production. ","replyToPid":0}
发表于 2020-1-8 06:16:29 来自手机 | 显示全部楼层
","text":"What? What? Do you not wash your windows? Do you not wash your truck. If you do then your sensors will be clean. The truck runs even if the sensors are faulty. ","replyToPid":299333}
发表于 2020-1-8 07:38:23 来自手机 | 显示全部楼层
366847 发表于 2020-01-07 22:17:03 Stop dude. Watch this channel. https://www.youtube.com/user/bjornnyland. He runs EVs in Norway or Sweden when its 0°F. He does just fine. Also not being able to find a charging station isn’t a permanent issue. That will disappear after mass uptake (https://apps.apple.com/us/app/plugshare/id421788217). The Tesla semi already runs batteries and car parts from Sparks NV to the Bay and Hawthorne CA. They do just fine going up and over the Rockies fully loaded even in the winter, and even better on mileage than originally stated at unveiling. With an EV you don’t have to run an engine to power accessories like the HVAC and entertainment. The Tesla semi can run an AC unit or it’s heater from the gigantic batteries meaning you’ll get through a closed road just fine. Also you charge everyday so you’ll have plenty of charge. If you’re a smart driver you already plan ahead and know about the weather ahead. If you know a hurricane is coming through down south you’re gonna top off your tanks before getting close right? It’s going to do just fine. Tesla is making patents on new battery chemistry’s. So are other manufacturers. John Goodenough has a new glass battery he’s working on which has more energy density than ones today so the packs will have more power in the same space.
","text":"This.","replyToPid":299654}
GMT+8, 2026-2-15 10:35 , Processed in 0.135494 second(s), 24 queries .
