查看: 58|回复: 5
Can you still play mmorpg if you are truck driving?
 楼主| 发表于 2020-1-7 11:14:24 来自手机 | 显示全部楼层 |阅读模式
{"text":"I mean, the internet connection on some areas will really be bad.  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-7 13:54:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"He is correct. Playing doesn’t use that much at all. It’s the updates and patches that are brutal to your data plan. Best advice I can give is update on pilot or loves WiFi while you are sleeping. ","replyToPid":0}
发表于 2020-1-7 14:00:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"An unlimited plan isn’t a bad idea. Then hotspot off your phone. When you start your truck it will probably turn off your console. Just do the update as you’re sleeping or driving. 🕹 ","replyToPid":0}
发表于 2020-1-7 13:50:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"pay for the highest plan with Verizon and then hotspot off your phone. The play doesn't use much data but the updates will","replyToPid":0}
发表于 2020-1-7 19:46:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unsure about an MMORPG but I run CoD on a PS4 using mobile hotspot and it doesn't lag unless I'm in one of those delightful 2-bar places.","replyToPid":0}
发表于 2020-1-8 10:47:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"What kind of ping do you guys get running on a hotspot?","replyToPid":0}
GMT+8, 2026-2-16 17:16 , Processed in 0.060298 second(s), 24 queries .
