查看: 96|回复: 5
Carrier or Thermo-king APU ?
 楼主| 发表于 2020-1-7 10:59:40 来自手机 | 显示全部楼层 |阅读模式
{"text":"I just can't get the Thermo king climate control to work right. Either it's too hot or too cold. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-8 02:43:43 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Also ditch the APU for an EPU. It uses no fuel and will auto crank your truck when the batteries get low. "}
发表于 2020-1-8 02:42:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s 2020 and we’re still using APU’s without digital thermostats ","replyToPid":0}
发表于 2020-1-7 12:17:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Make smaller adjustments. I went through that myself. It’s 32 degrees, I’ve got the thermostat between 1/4 and 1/2 and it’s 74 in the truck. You might have to suffer some extreme temps until you get it down. ","replyToPid":0}
发表于 2020-1-8 05:41:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"none get a EPU. no noise or fricking smell","replyToPid":0}
发表于 2020-1-8 11:08:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Espar.. thousands cheaper/works like a charm","replyToPid":0}
GMT+8, 2026-2-15 15:14 , Processed in 0.050350 second(s), 24 queries .
