查看: 141|回复: 24
What's the best thing that your trainer has taught you?
 楼主| 发表于 2020-1-7 09:09:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"hmmm.  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-7 09:12:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"dont let the other drivers rush you take you time and be safe","replyToPid":0}
发表于 2020-1-7 09:34:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"\"Never expect that you've learned everything there is to know [about truck driving]. If you believe that, you shouldn't be on the road.\"","replyToPid":0}
发表于 2020-1-7 09:26:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"The only Dumb thing you can do, is not ask a question.","replyToPid":0}
发表于 2020-1-7 09:48:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Trailers can’t jump sideways don’t be afraid of narrow construction zones","replyToPid":0}
发表于 2020-1-7 10:02:38 来自手机 | 显示全部楼层
662650 发表于 2020-01-07 01:34:16 \"Never expect that you've learned everything there is to know [about truck driving]. If you believe that, you shouldn't be on the road.\"
","text":"Exactly ","replyToPid":299082}
发表于 2020-1-7 10:09:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Go slow","replyToPid":0}
发表于 2020-1-7 11:52:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"When you need to change lanes, some times you need to just force your way into that other lane.","replyToPid":0}
发表于 2020-1-7 12:02:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Trip planning, weights & measures, & what not to do at truck stops.","replyToPid":0}
发表于 2020-1-7 22:19:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"That dispatch will try to get you to do stuff that you're not supposed to do, or they'll try to get you to move forward, even if there's bad weather. DON'T DO IT, especially if you're not comfortable.","replyToPid":0}
GMT+8, 2026-2-16 17:17 , Processed in 0.087234 second(s), 24 queries .
