查看: 132|回复: 10
Reefer Madness 😂
 楼主| 发表于 2020-1-7 01:30:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"Yep. ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":384.0,\"name\":\"\",\"url\":\"\",\"width\":640.0}]","canComment":true,"externalShare":false}
发表于 2020-1-7 04:54:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"we pull reffer and when the unit is running is when I get the best sleep","replyToPid":0}
发表于 2020-1-7 04:09:23 来自手机 | 显示全部楼层
{"replyToPid":298811,"replyTo":"
805928 发表于 2020-01-06 19:35:54 poor baby, I bet you don't turn the engine on to idle for heat or a/c and also dont use an apu either
","text":"Nope trucks now have internal apu where there’s extra batteries to run ac/heat for 14 hours. So no idling and no apu engine running. "}
发表于 2020-1-7 04:53:49 来自手机 | 显示全部楼层
","text":"typical premadon","replyToPid":298811}
发表于 2020-1-7 03:35:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"poor baby, I bet you don't turn the engine on to idle for heat or a/c and also dont use an apu either","replyToPid":0}
发表于 2020-1-7 05:20:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"I pull reefer. what does it take for one to be a primadonna?","replyToPid":298872}
发表于 2020-1-7 04:45:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Maybe you should pull reefer make some money they don’t make much more noise than APU","replyToPid":0}
发表于 2020-1-7 04:53:10 来自手机 | 显示全部楼层
295387 发表于 2020-01-06 20:45:42 Maybe you should pull reefer make some money they don’t make much more noise than APU
","text":"reefers suck and I know because I use to do reefer hauling. and your smelly api's and so fricking noisy as I have my Peterbilt with a E P U running not making a sound.","replyToPid":298861}
发表于 2020-1-7 09:58:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"I pull reefer. sometimes I wake up in the middle of the night and can't even hear it running. I have to feel the back of the sleeper wall for the vibration to make sure it's still going. some people have tender ears I guess.","replyToPid":0}
发表于 2020-1-7 10:15:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"If noise from an engine kept you awake, we'd all be like the Energizer Bunny!","replyToPid":0}
GMT+8, 2026-2-15 19:20 , Processed in 0.091931 second(s), 24 queries .
