查看: 105|回复: 9
Is getting a Hazmat endorsement worth it?
 楼主| 发表于 2020-1-6 11:10:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"What are your thoughts on it?  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-6 17:54:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Barely, but it might mean that one load that will get you to/out of a better area.","replyToPid":0}
发表于 2020-1-6 15:10:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you're tanker or looking for a new carrier I would say yes, a lot of good carriers require the endorsement","replyToPid":0}
发表于 2020-1-6 15:08:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes","replyToPid":0}
发表于 2020-1-6 15:18:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Had it , it all depends, one pallet is sometimes worth full load, but the shit you go thru! ","replyToPid":0}
发表于 2020-1-6 15:18:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Had it , it all depends, one pallet is sometimes worth full load, but the s@hityou go thru! ","replyToPid":0}
发表于 2020-1-6 16:20:25 来自手机 | 显示全部楼层
发表于 2020-1-6 16:44:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"had it when I drove tankers. now I drive refer and flatbed haven't needed it sence, so when it was time to re-up the endorsement I chose not to. if you go for it, make sure you study for it. it is a long test.","replyToPid":0}
发表于 2020-1-6 20:55:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"If your carrier hauls a lot of hazmat it’s worth it if it pays more. If your carrier has you haul 5 loads a year at .10 cents per mile more then I’d say no way.","replyToPid":0}
发表于 2020-1-6 21:16:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"no, exposure will slowly kill you 10 years ahead of schedule.","replyToPid":0}
GMT+8, 2026-2-15 20:47 , Processed in 0.057221 second(s), 24 queries .
