查看: 131|回复: 3
Can you drain air tanks by pumping brakes?
 楼主| 发表于 2020-1-6 10:24:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"A friend of mine theorized that you can remove moisture in the air tanks by pumping down the brakes till the pressure reads zero. I'm not sure if that is effective and I cant find any literature only that talks about this.  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-6 14:11:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"no, you can not.","replyToPid":0}
发表于 2020-1-6 13:53:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"The water is at the bottom of the tanks and wouldn’t magically be sucked out somewhere with only ambient air pressure. It may just drain out if you opened the valve but the air pressure pushes it out with force. If the cable broke, you’ll have to get to the tank valve and manually pull on it with pliers or vice grips. You don’t want water in your air system especially if it freezes.","replyToPid":0}
发表于 2020-1-6 22:01:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get a valve adapter & open from the bottom.","replyToPid":0}
GMT+8, 2026-2-15 20:48 , Processed in 0.053142 second(s), 24 queries .
