查看: 261|回复: 15
Maine State Troopers stopped a tractor trailer that was driving with no trailer brakes.
 楼主| 发表于 2020-1-5 10:43:41 来自手机 | 显示全部楼层 |阅读模式
{"text":"Thoughts?  ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":546.0,\"name\":\"176241/15_1578192213_1578192214.png\",\"url\":\"\",\"width\":812.0}]","canComment":true,"externalShare":false}
发表于 2020-1-5 23:05:58 来自手机 | 显示全部楼层
724453 发表于 2020-01-05 04:51:58 they're wireless officer, new wifi lines, how do you think I was able to stop?
","text":"My lines use blutooth","replyToPid":297657}
发表于 2020-1-5 23:15:29 来自手机 | 显示全部楼层
803421 发表于 2020-01-05 13:12:47 You must not drive truck..
","text":"Yes sir I do or else I wouldn't have paid for this subscription. Just wasn't thinking when I first commented. All though I was man enough to admit that I was wrong and corrected myself.","replyToPid":297749}
发表于 2020-1-5 11:06:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"It happens, mine came off on me 2x ","replyToPid":0}
发表于 2020-1-5 11:27:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"(Subject to one's rational thought.)","replyToPid":0}
发表于 2020-1-5 11:31:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"zip tie those things on. that's what I do","replyToPid":0}
发表于 2020-1-5 11:32:17 来自手机 | 显示全部楼层
880983 发表于 2020-01-05 03:13:53 Not even a service line on the truck. \n\nThoughts?
","text":"His trailer brakes would have been locked up with the blue line off","replyToPid":297575}
发表于 2020-1-5 11:41:59 来自手机 | 显示全部楼层
870297 发表于 2020-01-05 03:32:17 His trailer brakes would have been locked up with the blue line off
","text":"Would lock up with the red of , \nBlue is only when u press brakes ","replyToPid":297585}
发表于 2020-1-5 11:57:58 来自手机 | 显示全部楼层
580577 发表于 2020-01-05 03:41:59 Would lock up with the red of , \nBlue is only when u press brakes
","text":"pull yours off and see what happens","replyToPid":297594}
发表于 2020-1-5 12:05:01 来自手机 | 显示全部楼层
","text":"yes you are correct.","replyToPid":297594}
发表于 2020-1-5 12:06:56 来自手机 | 显示全部楼层
","text":"correct myself... looked closer you are correct the entire service line is missing. Maybe someone needed it more.","replyToPid":297585}
发表于 2020-1-5 12:35:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s fine, just use your gears to slow you down. Good practice for driving on ice","replyToPid":0}
GMT+8, 2026-2-16 00:45 , Processed in 0.076442 second(s), 24 queries .
