查看: 106|回复: 5
CB Issues
 楼主| 发表于 2020-1-5 06:44:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"I recently bought myself a Cobra 29LX and Firestik KW3 antennas; after install and tuning, I am not hearing any chatter on channel 19, even sitting in a truck stop. Any trouble shooting suggestions since my carrier will not touch our CBs; I am about at the point of contacting a CB/audio shop for help?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-8 01:18:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"unless you're driving a peterbilt or classic freightliner your antenna mounts aren't grounded. you need a no ground plane antenna or direct ground to frame/metal and then you'll really hear all the chatter.","replyToPid":0}
发表于 2020-1-8 01:06:32 来自手机 | 显示全部楼层
811116 发表于 2020-01-07 15:52:51 Thanks for the help and I may have gotten it dialed in.
","text":"You're welcome and good luck ","replyToPid":299463}
发表于 2020-1-5 07:03:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Most likely you have a switch in the wrong position or the squelch turned up to high or no one (doubtful) has their CBs on. Keep trying, but if you have no luck, see a CB shop. ","replyToPid":0}
 楼主| 发表于 2020-1-7 23:52:51 来自手机 | 显示全部楼层
674254 发表于 2020-01-04 23:03:22 Most likely you have a switch in the wrong position or the squelch turned up to high or no one (doubtful) has their CBs on. Keep trying, but if you have no luck, see a CB shop.
","text":"Thanks for the help and I may have gotten it dialed in. ","replyToPid":297253}
 楼主| 发表于 2020-1-8 07:33:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m in a KW 680 but I believe the antennas I bought solve that issue. Seems much better now but will still have it looked at","replyToPid":0}
GMT+8, 2026-3-21 03:35 , Processed in 0.084386 second(s), 24 queries .
