查看: 178|回复: 8
I would like to know if anybody has a simple way to increase the goverened speed on a big truck.
 楼主| 发表于 2020-1-5 04:23:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"Any vialble suggestions would be greatly appreciated.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-5 09:03:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"And you may lose your job (if it is a company truck).","replyToPid":0}
发表于 2020-1-5 10:11:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"be careful if you're engine data is collected by your employer changing their setting could get you fired if you're a company driver","replyToPid":0}
发表于 2020-1-5 05:00:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"pedal faster and or harder","replyToPid":0}
发表于 2020-1-5 04:32:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"the dealership","replyToPid":0}
发表于 2020-1-5 04:42:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"you have to have the ecm programmed.   about 50 bucks","replyToPid":0}
发表于 2020-1-5 08:13:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes, ecm reprogram. Although it might cost a few hundred. ","replyToPid":0}
发表于 2020-1-5 13:10:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"go down grades in high gear, works like a charm","replyToPid":0}
发表于 2020-1-5 13:21:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"get going about 85 down hill turn key off keep it in gear 4 about 1mi then turn key on bump start it should reset top speed","replyToPid":0}
GMT+8, 2026-4-19 02:49 , Processed in 0.164123 second(s), 24 queries .
