查看: 61|回复: 1
Is a flat airbag a dot violation?
 楼主| 发表于 2020-1-5 03:35:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"Just a curious question","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-5 10:19:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Most likely, since it my reflect possible air leak . For example : if your tire is low on air, it can be seen as out of service ( depending how much psi is in the tire ) . ","replyToPid":0}
GMT+8, 2026-4-17 11:36 , Processed in 0.136715 second(s), 23 queries .
