查看: 134|回复: 6
Food restriction
 楼主| 发表于 2020-1-4 04:20:14 来自手机 | 显示全部楼层 |阅读模式
{"text":"Have you ever limited the amount of food or water you ingest, for the purpose of stopping less to use the bathroom?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2020-1-4 05:22:45 来自手机 | 显示全部楼层
880983 发表于 2020-01-03 20:34:22 No. \n\nYou don’t eat ya dont💩. \n\nDon’t💩. \n\nYou die. \n\nSimple
","text":"Dam, ya can't argue with that logic...","replyToPid":296472}
 楼主| 发表于 2020-1-4 05:34:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was laughing at your first comment but it posted it on this comment... Oh well.... But you are right, can actually burn the calories/ food ..","replyToPid":0}
发表于 2020-1-4 06:31:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you just sip water to keep mouth wet you won’t stop as much to pee. If you don’t know what makes you sit and dump you will learn real quick on what to eat and how much when doing this job. Common sense with that goes a long way","replyToPid":0}
 楼主| 发表于 2020-1-4 05:28:10 来自手机 | 显示全部楼层
848274 发表于 2020-01-03 21:27:06 wanna 💩 less?\nget extremely active and burn the calories by sweating and let your muscles feed. I know it's hard seeing as none of of have a set schedule & can't always park near the gym, but it's doable
","text":"🤣🤣🤣🤣","replyToPid":296501}
发表于 2020-1-4 08:20:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"STAY AWAY FROM THE THAI FOOD!!!!😰","replyToPid":0}
发表于 2020-1-4 13:08:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have never limited my food or water intake. I’m height and weight proportionate ","replyToPid":0}
GMT+8, 2026-2-16 03:32 , Processed in 0.060218 second(s), 24 queries .
