查看: 338|回复: 24
Question about truck stop parking
 楼主| 发表于 2020-1-3 10:02:57 来自手机 | 显示全部楼层 |阅读模式
{"text":"I drive refer and was wondering if there’s some trucker rule when parking a refer at a truck stop, even I feel bad for the trucker sitting next to me that has to hear the noise while trying to sleep, thanks tp fam","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-3 11:09:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've pulled a refer for around 40 years, I usually try to park backwards on the back row, mainly to protect my front end from the rookies and make it quite for everyone else,,or else I park and sleep on a get on ramp if I'm in a state that won't write a ticket for it","replyToPid":0}
回复 支持 6 反对 0
发表于 2020-1-3 11:29:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Reefers don't bother me, I sleep like a baby. I mean if you can sleep with your own truck running, esp if you drive reefer, I don't see how anyone has a problem with it.","replyToPid":0}
发表于 2020-1-3 13:37:38 来自手机 | 显示全部楼层
686228 发表于 2020-01-03 04:47:56 flatbed dont have reefer units. they are not use to the noise. try to be considerate but unless you park at 1600 like some they just going to have to deal w it.
","text":"yes but most have apu their on and off all night, I put my refer on continuous that way it's not on and off","replyToPid":296198}
发表于 2020-1-3 14:59:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't mind sleeping next to a reefer, it's no worse than a truck idling all night with their air dryer going off every 30 seconds","replyToPid":0}
发表于 2020-1-3 12:47:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"flatbed dont have reefer units. they are not use to the noise. try to be considerate but unless you park at 1600 like some they just going to have to deal w it.","replyToPid":0}
发表于 2020-1-3 15:32:01 来自手机 | 显示全部楼层
852030 发表于 2020-01-03 03:36:37 I know there are some that mind
","text":"When in doubt, F**K IT! Your well-being should be your concern. If the others can't sleep, rest, or whatever, it's on them. Reefer pullers have no control of how loud that engine is running. \n\nBesides, an engine running is better than one quitting while in transit.","replyToPid":296143}
发表于 2020-1-3 12:42:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't park next to a flat bed if at all possible.","replyToPid":0}
 楼主| 发表于 2020-1-3 11:36:37 来自手机 | 显示全部楼层
808178 发表于 2020-01-03 03:29:04 Reefers don't bother me, I sleep like a baby. I mean if you can sleep with your own truck running, esp if you drive reefer, I don't see how anyone has a problem with it.
","text":"I know there are some that mind","replyToPid":296141}
 楼主| 发表于 2020-1-3 11:35:22 来自手机 | 显示全部楼层
871163 发表于 2020-01-03 03:09:38 I've pulled a refer for around 40 years, I usually try to park backwards on the back row, mainly to protect my front end from the rookies and make it quite for everyone else,,or else I park and sleep on a get on ramp if I'm in a state that won't write a ticket for it
","text":"Never thought about that will try that next time, our company doesn’t allow parking on streets or off/on ramps, thank you sir","replyToPid":296129}
发表于 2020-1-4 05:09:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unless your parking at 1600 or 1700 your going to be lucky to get a spot at numerous truck stops. My input is too grab whatever spot you can get and don't worry about your reefer noise. 99.9 percent of truck drivers don't care anyways.","replyToPid":0}
 楼主| 发表于 2020-1-3 12:43:41 来自手机 | 显示全部楼层
878756 发表于 2020-01-03 04:42:07 I don't park next to a flat bed if at all possible.
","text":"Why is that?","replyToPid":296190}
 楼主| 发表于 2020-1-3 12:54:30 来自手机 | 显示全部楼层
","text":"True, thank you sir","replyToPid":296198}
GMT+8, 2026-2-15 22:00 , Processed in 0.074995 second(s), 24 queries .
