查看: 113|回复: 9
For some, Why would a truck take a lot of tries to start?
 楼主| 发表于 2020-1-3 04:27:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"Has this happened to you?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-3 09:21:54 来自手机 | 显示全部楼层
{"replyToPid":296068,"replyTo":"
871163 发表于 2020-01-03 01:15:50 it's in the backside of the filter head, looks like a plug, takes a 3/4 to pull it out, I always carry a spare \n the one on the Detroit's looks like a ordinary fitting, top fitting on the head, is a pain to get to on most trucks, gotta do it by feel because you can't see it if the engine is in the truck,
","text":"Thanks, I’ll check it out. "}
发表于 2020-1-3 08:35:55 来自手机 | 显示全部楼层
871163 发表于 2020-01-02 23:35:17 if it's a Detroit probably the check valve in the back of the head allowing the fuel to drain back outta the head,if it's a cat the same valve is located on the main filter head
","text":"Never heard of that, had 3 cats and never seen a valve near fuel filter. ","replyToPid":295997}
发表于 2020-1-3 04:36:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Must be loosing fuel pressure maybe plugged fuel filter ","replyToPid":0}
发表于 2020-1-3 06:03:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"What motor? What year? All important info!","replyToPid":0}
发表于 2020-1-3 07:35:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"if it's a Detroit probably the check valve in the back of the head allowing the fuel to drain back outta the head,if it's a cat the same valve is located on the main filter head","replyToPid":0}
发表于 2020-1-3 08:19:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did you check your valve cap 🤷🏻‍♂️","replyToPid":0}
发表于 2020-1-3 08:35:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"sometimes air can get into the fuel filter if your fuel filter isn't completely full usually start real rough or won't start","replyToPid":0}
发表于 2020-1-3 09:15:50 来自手机 | 显示全部楼层
885206 发表于 2020-01-03 00:35:55 Never heard of that, had 3 cats and never seen a valve near fuel filter.
","text":"it's in the backside of the filter head, looks like a plug, takes a 3/4 to pull it out, I always carry a spare \n the one on the Detroit's looks like a ordinary fitting, top fitting on the head, is a pain to get to on most trucks, gotta do it by feel because you can't see it if the engine is in the truck,","replyToPid":296027}
发表于 2020-1-3 12:06:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Make sure your starters not about to go","replyToPid":0}
GMT+8, 2026-2-16 04:49 , Processed in 0.061737 second(s), 24 queries .
