查看: 116|回复: 8
States I peed in in 2019.
 楼主| 发表于 2020-1-3 03:04:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"All of em. But Trucker Path didn’t record it ☹️","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1008.0,\"name\":\"\",\"url\":\"\",\"width\":568.0}]","canComment":false,"externalShare":false}
发表于 2020-1-3 17:35:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"They shall now add the yellow wee dot just for you!\n\nJust tap the dot 👉🌕 when you stop to pull up your current whizzing location. \nAnd then, choose the quality/quantity \n🔴Lots of Pee Left\n🔵Some Pee Left\n⚪No Pee Left\n\nThis would greatly help other happy truckers find that perfect place to lift a leg and let er wee. Make sure to leave any important comments, such as prevalent wind direction, road grade-level, especially in the case of steep uphill grades, and terrain conditions, such as mud, ice or wet  ground so others may be as safe as possible without fear of dribbles upon themselves","replyToPid":0}
 楼主| 发表于 2020-1-3 22:27:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Review of Joe’s Waterin’ Hole:\n📍🟡🔴 \nBig lot, not finished yet. The construction crew seemed annoyed and confused that I was there. How rude! I made sure to make eye contact with the foreman while he yelled at me while relieving myself; it helps me relax. 10/10 would pee again. ","replyToPid":0}
 楼主| 发表于 2020-1-3 22:23:04 来自手机 | 显示全部楼层
780067 发表于 2020-01-03 09:35:33 They shall now add the yellow wee dot just for you!\n\nJust tap the dot 👉🌕 when you stop to pull up your current whizzing location. \nAnd then, choose the quality/quantity \n🔴Lots of Pee Left\n🔵Some Pee Left\n⚪No Pee Left\n\nThis would greatly help other happy truckers find that perfect place to lift a leg and let er wee. Make sure to leave any important comments, such as prevalent wind direction, road grade-level, especially in the case of steep uphill grades, and terrain conditions, such as mud, ice or wet  ground so others may be as safe as possible without fear of dribbles upon themselves
","text":"Thanks, that’s a useful feature. ","replyToPid":296291}
 楼主| 发表于 2020-1-3 22:42:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Oregon is a myth. Like North Dakota. I heard it will appear on a map, but you have to believe it’s there. ","replyToPid":296294}
发表于 2020-1-3 17:39:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"forgot Oregon","replyToPid":0}
发表于 2020-1-3 23:48:56 来自手机 | 显示全部楼层
497499 发表于 2020-01-03 14:23:04 Thanks, that’s a useful feature.
","text":"Just make sure to note if there's like, rocks or shrubbery handy for us girls that prefer to use a little discretion on the side of the road lol","replyToPid":296335}
 楼主| 发表于 2020-1-4 03:22:08 来自手机 | 显示全部楼层
780067 发表于 2020-01-03 15:48:56 Just make sure to note if there's like, rocks or shrubbery handy for us girls that prefer to use a little discretion on the side of the road lol
","text":"Will do. Also pro tip: If you’re the shy type, you can always go peepee from the comfort of your trailer. Plus it keeps the raccoons away. \nThe More You Know 🌈 ","replyToPid":296358}
发表于 2020-1-4 03:32:16 来自手机 | 显示全部楼层
497499 发表于 2020-01-03 19:22:08 Will do. Also pro tip: If you’re the shy type, you can always go peepee from the comfort of your trailer. Plus it keeps the raccoons away. \nThe More You Know 🌈
","text":"Flatbed.\nCurtain and a bucket for me 🤣","replyToPid":296428}
GMT+8, 2026-2-16 12:34 , Processed in 0.057066 second(s), 24 queries .
