查看: 91|回复: 2
i80 closure
 楼主| 发表于 2020-1-2 20:07:08 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm at WY Evanston city heading to east, I see i80 has closed because of weather.\n\nwhat do you guys do in the same condition, do you change the road or wait?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-3 11:20:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"generally wait. In WY, if they close the interstate, the secondary roads are not treated or plowed either. spent 38hrs at Little America. it opened up about 0900 thur.","replyToPid":0}
发表于 2020-1-4 00:16:33 来自手机 | 显示全部楼层
65688 发表于 2020-01-03 03:20:17 generally wait. In WY, if they close the interstate, the secondary roads are not treated or plowed either. spent 38hrs at Little America. it opened up about 0900 thur.
","text":"definitely don't run that country in winter with out  a weeks supplies wich includes a couple gallons of bleach to pour on your tires if they freeze to pavement while your parked somewhere just pour it on rubber heats up and you can go if you don't do this you may drop a driveshaft or pull rubber loose from tire casing","replyToPid":296134}
GMT+8, 2026-4-17 08:39 , Processed in 0.091636 second(s), 23 queries .
