查看: 481|回复: 22
As a newbie how do you know which Walmarts let you park overnite and which ones will not? Goin to CDL school in 11 days
 楼主| 发表于 2020-1-2 10:20:23 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-1-2 21:27:50 来自手机 | 显示全部楼层
877513 发表于 2020-01-02 13:20:33 See that's what I'm talkin about. I see vids with crammed truck stops with no available spaces. I'm just looking for alternatives to be prepared. Industrial parks? TY
","text":"industrial areas.  abandoned malls.  there are places if you are really desperate.  focus on trip planning when you start and you really shouldn't have an issue with finding parking.","replyToPid":295523}
发表于 2020-1-2 10:33:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"typically as a driver you shouldn't have to worry about parking at a Walmart for the overnight.  just prepare yourself and plan ahead.  if Walmart is a must usually you can tell by the parking lot setup or if there are other trucks parked out front","replyToPid":0}
发表于 2020-1-4 16:31:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Try the Allstays App for Camping and RV it lists Parking at Walmart, Cracker Barrel Etc","replyToPid":0}
发表于 2020-1-3 12:40:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"you have to be creative. where you are geographically is also a huge factor.  midwest is flush w truck stops but northeast is small travel plazas. weigh stations usually have a lot out back for inspections and never once have I been hassled there. load planning is a great concept but not everyone can stop at 1600 for the night. just dont park on the side of highway. you might not wake up.","replyToPid":0}
发表于 2020-1-3 09:24:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"I park at Walmart’s all the time and have never had a problem. Here is how:\n\nMake sure the Walmart is a superwalmart and is 24/7 and you’re pretty much good to go. Also speak with a manager or the lead at customer service just to make sure. Lastly park in the white lines in the back right not the yellow lines or anywhere in the grocery pickup areas.\n\nPark at non 24/7 Walmarts at your own risk.","replyToPid":0}
发表于 2020-1-3 05:43:06 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"not worth the risk do proper time management and never spend the night at Walmart because one manager may tell you sure you can park over night then anouther one comes in and says no you can't then your screwed 31 years OTR never spent the night in a Walmart and I can count on one hand the number of times I spent the night in rest area do proper time management and park in truck stops"}
发表于 2020-1-3 01:20:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Definitely call and talk to a manager. Just because other trucks are parked there does not mean they allow it. Dont take a chance and risk getting booted and towed.... always call and ask","replyToPid":0}
发表于 2020-1-2 22:04:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you are hauling something that the store needs to operate (not store merchandise), I found even the most anti-truck walmarts will allow you to park there overnight.","replyToPid":0}
发表于 2020-1-2 13:02:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"(FYI, don't go to any Wal-Mart along I-75 in KY. Otherwise, you'll be hundreds of dollars shorter from being booted.)","replyToPid":0}
发表于 2020-1-2 14:09:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"never stayed at a Walmart. every town has an industrial section if truck stops are full.","replyToPid":0}
发表于 2020-1-2 10:44:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Call or stop in and talk to a manager if it's your only option. Usually as long as you go to a vacant area of the lot, promise not to liter or use the lot as a restroom and you're out of there before it gets busy, they will let you in some of the small town lots. Just remember to position yourself to where you're facing an exit and that you have a little curb room and room in front and back of you to maneuver in case some joker in a 4 wheeler or camper trailer parks too close to you. Believe me, it happens. But give yourself some wiggle room without sticking out. Usually they'll let you in for a full 10","replyToPid":0}
发表于 2020-1-2 10:52:32 来自手机 | 显示全部楼层
780067 发表于 2020-01-02 02:44:46 Call or stop in and talk to a manager if it's your only option. Usually as long as you go to a vacant area of the lot, promise not to liter or use the lot as a restroom and you're out of there before it gets busy, they will let you in some of the small town lots. Just remember to position yourself to where you're facing an exit and that you have a little curb room and room in front and back of you to maneuver in case some joker in a 4 wheeler or camper trailer parks too close to you. Believe me, it happens. But give yourself some wiggle room without sticking out. Usually they'll let you in for a full 10
","text":"I avoid Walmart parking unless I’m shopping or delivering, but I put triangles in the spaces in front and behind me to give myself room to swing out. ","replyToPid":295329}
发表于 2020-1-2 10:59:37 来自手机 | 显示全部楼层
497499 发表于 2020-01-02 02:52:32 I avoid Walmart parking unless I’m shopping or delivering, but I put triangles in the spaces in front and behind me to give myself room to swing out.
","text":"I did that once in Mustang Oklahoma several years ago. Woke up a few hours later to go use the little girls room...All 3 triangles, two oversized load banners, 4 red flags and 2 safety lights less later. Never again lol","replyToPid":295335}
发表于 2020-1-2 11:14:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"i always check the reviews on Google maps first.  or if it looks like a truckstop in therr than its safe to assume its ok.","replyToPid":0}
发表于 2020-1-2 13:31:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"You don't","replyToPid":0}
发表于 2020-1-2 15:01:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"all Walmart's in around Atlanta. you will get booted.check with store manager or security guard","replyToPid":0}
GMT+8, 2026-4-17 10:13 , Processed in 0.153882 second(s), 24 queries .
