查看: 376|回复: 24
No grip to slide tandems
 楼主| 发表于 2019-12-31 18:10:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"Been stuck at a shippers for 2 hrs now cuz I can't slide the tandems back. They haven't cleaned the lot yet. Does anyone know what to do?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-31 18:34:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Try and block your rears with a few 2×4s, wheel chock. If that doesn't work back your rear tandems up against a curb or something that will help hold while you adjust. \n\nWatch your mudflaps and clearance for your Icc bar, etc. \n\nGo Slow and think about all your steps before you hit that fuel lever. \n\nHope this helps.  \n\nCheers!","replyToPid":0}
发表于 2020-1-1 01:23:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lock differential set parking brake use low gear and try to move forward. When you feel it starting to pull release the break and it should sling you out of the spot. What this does is keep the wheels from free spinning forcing the other to grab. Might take a few times and might need 2nd gear but it’s always got me unstuck","replyToPid":0}
发表于 2019-12-31 18:50:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I used my top bunk matters once!😂","replyToPid":0}
发表于 2019-12-31 20:14:20 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"kitty litter is your friend in the winter"}
发表于 2019-12-31 22:42:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"chain up","replyToPid":0}
发表于 2019-12-31 23:14:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Chain'em up and get rollin. Been there, done it.","replyToPid":0}
发表于 2019-12-31 21:06:04 来自手机 | 显示全部楼层
724453 发表于 2019-12-31 12:14:20 kitty litter is your friend in the winter
","text":"very true! but make sure you get the old style regular clay litter. That stuff that clumps just turns into slippery snotty slime lol","replyToPid":294166}
 楼主| 发表于 2019-12-31 19:52:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Creativity at its finest. Thanks for the ideas and help. I was finally able to get unstuck, but now unable to slide the tandems. I will need to shut down until they decide to salt the lot. Thanks again.","replyToPid":0}
发表于 2019-12-31 18:25:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have you tried moving to a different spot in the lot","replyToPid":0}
发表于 2019-12-31 19:33:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Always carry a bag of salt for stuff like this.","replyToPid":0}
发表于 2019-12-31 18:26:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sometimes this will help ","replyToPid":0}
发表于 2019-12-31 18:31:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"slide the tandems at all cost","replyToPid":0}
 楼主| 发表于 2019-12-31 18:39:15 来自手机 | 显示全部楼层
675117 发表于 2019-12-31 10:25:51 Have you tried moving to a different spot in the lot
","text":"Unfortunately, I'm stuck in front of some trailers. I can't move forward or backwards. I tried to shovel out the snow from around the drive tires, but nothing seems to work.","replyToPid":294144}
 楼主| 发表于 2019-12-31 18:40:56 来自手机 | 显示全部楼层
626560 发表于 2019-12-31 10:34:07 Try and block your rears with a few 2×4s, wheel chock. If that doesn't work back your rear tandems up against a curb or something that will help hold while you adjust. \n\nWatch your mudflaps and clearance for your Icc bar, etc. \n\nGo Slow and think about all your steps before you hit that fuel lever. \n\nHope this helps.  \n\nCheers!
","text":"Thanks for the info. I'm not having issues with the trailer tires, it's my drive tires. They just keep spinning because there's no grip. I wish I had a 2 x 4 or something to put under them. I'll have to start carrying one of those.","replyToPid":294149}
发表于 2019-12-31 18:49:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do you have anything you can put under the drivers to help you get moving at all . Floor mats? Anything you don’t mind not getting back. Cause it’ll be fucked when you’re done. Or you will have to wait for help.","replyToPid":0}
GMT+8, 2026-4-19 01:05 , Processed in 0.108013 second(s), 24 queries .
