查看: 385|回复: 18
Do You See What I See?
 楼主| 发表于 2019-12-31 06:52:28 来自手机 | 显示全部楼层 |阅读模式
{"text":"This guy pulled away from his load and forgot to lower his landing gear. Just had to share.  😂 \n\nStay safe everyone! ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0}]","canComment":true,"externalShare":false}
发表于 2019-12-31 20:23:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"(A few more inches: F**K!)","replyToPid":0}
发表于 2019-12-31 19:32:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Fortunately, only because the trailer is still resting on the frame, that's an easy fix.","replyToPid":0}
发表于 2020-2-29 15:57:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"ive been there done that never happened again.","replyToPid":0}
发表于 2020-1-1 07:25:45 来自手机
{"replyTo":"","text":"I’ve forgot to disconnect the airlines a couple times lol.....stop when I heard them hit the cab ","replyToPid":0}
支持 2 反对 0
68
发表于 2020-3-1 11:55:47 来自手机 | 显示全部楼层
850052 发表于 2020-01-01 12:43:55 I learned a valuable lesson, double check before I get back into my truck!
","text":"You so mean girl ","replyToPid":294834}
发表于 2019-12-31 21:47:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"They where in to much of hurry or talking on phone and forgot ","replyToPid":0}
发表于 2019-12-31 22:17:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well he learned a valuable lesson😂","replyToPid":0}
发表于 2020-1-1 00:28:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve watched that happen, I went and helped crank one up, it blows, but at least  he or she stopped where they did","replyToPid":0}
发表于 2020-3-4 02:41:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"I can’t remember if I did that or it was another driver but I’ve cranked them up before and helped others. My favorite is when I forget to unhook my air lines 😁","replyToPid":0}
发表于 2020-1-2 01:36:51 来自手机 | 显示全部楼层
","text":"Is always a good practice because people will pull your pin for a lot of reasons or if it’s very cold out sometimes when you hook up to a trailer it won’t catch and you’ll pull away and there’s goes your trailer, rookie move","replyToPid":294834}
发表于 2019-12-31 21:43:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Uh oh","replyToPid":0}
发表于 2020-1-1 00:28:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve watched that happen, I went and helped crank one up, it sucks, but at least  he or she stopped where they did","replyToPid":0}
发表于 2020-1-1 07:25:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve forgot to disconnect the airlines a couple times lol.....stop when I heard the bang bang lol","replyToPid":0}
 楼主| 发表于 2020-1-1 20:43:55 来自手机 | 显示全部楼层
649294 发表于 2019-12-31 14:17:33 Well he learned a valuable lesson😂
","text":"I learned a valuable lesson, double check before I get back into my truck! ","replyToPid":294207}
GMT+8, 2026-2-13 22:38 , Processed in 0.135124 second(s), 24 queries .
