查看: 317|回复: 36
I'm bored....
 楼主| 发表于 2019-12-31 04:05:26 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does anyone else PC to the nearest truck stop in the morning for a shower and whatnot after getting stuck at a rest area the night before?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-31 11:16:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Must be company driver. I own mine. I can pc anytime I want as long as it is legal to do so","replyToPid":293907}
发表于 2019-12-31 13:04:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Drivers Do the reasearch, protect your CDl. Why is this so hard? Its your livelehood, your profession, YOUR responsibility.  \n\nTake the time, read the green book, google Info, learn the laws.\n\n Asking for advise from this forum will get you wrong answers that will get you in trouble with YOUR CDL, employer, amd your money.   \n\nCHEERS! \n\nLEARN YOUR SH*T!","replyToPid":0}
发表于 2019-12-31 12:59:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"It ain't cheating, till u get caught.","replyToPid":0}
发表于 2019-12-31 12:28:35 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"PC wherever you want. to the gym, store, movies.  End of story."}
发表于 2019-12-31 11:18:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can actually if it is too reach a safety rest area. All you do is put in comments \"forced to move\" then head over to Truckstop. Doesn't mean drive 100 miles just to nearest safety rest area or truck stop","replyToPid":0}
发表于 2019-12-31 10:45:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"I won’t pc if it’s on the way","replyToPid":0}
发表于 2019-12-31 12:30:26 来自手机 | 显示全部楼层
688983 发表于 2019-12-31 02:51:25 Do what you can get away with.  \nBut you can't use P.C. to further yourself down the road . \nIf it's less then 10 miles go for it.
","text":"Your incorrect Driver.  Please don't give advice If your not familiar with current Rules and regs.","replyToPid":293923}
发表于 2019-12-31 13:27:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"So, I will break it down what is legal. \n\nYou grab a load @point A. \n\nYou have to run to point D.\n\nYou run out of hours and stop go into slepper. Then you want to go to the gym before your hours are up. So you pc to point B, workout, finish your 10 hour break then roll on. \n\nThen you run on day 2 and run out of hours, go into sleeper then pc to a store because you need food. Your rest started when you went into sleeper. And your pc is not counted against that.  If your laden or not and if point D is  on your way then this is legal.  \n\nDoes this make sense? Your not gonna go backwards and this is from FMSCA.","replyToPid":0}
发表于 2019-12-31 11:35:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t PC very often, but if I have a feeling that I won’t be able to take a shower at the end of the day, I’ll do it on my 30 minute break, it’ll just end up being a little longer of a break 😊","replyToPid":0}
发表于 2019-12-31 10:38:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Can't anymore...ELD","replyToPid":0}
发表于 2019-12-31 04:09:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sometimes","replyToPid":0}
发表于 2019-12-31 10:36:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I do it all the time","replyToPid":0}
发表于 2019-12-31 10:43:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have and I do. ","replyToPid":0}
发表于 2019-12-31 10:46:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"why can't you?","replyToPid":293907}
GMT+8, 2026-2-11 21:02 , Processed in 0.129702 second(s), 24 queries .
