查看: 288|回复: 12
Looking for mechanical advice
 楼主| 发表于 2019-12-30 19:36:56 来自手机 | 显示全部楼层 |阅读模式
{"text":"Any driver/mechanics have a idea why there’s a diesel smell in the antifreeze? I know it can’t be right but just wanting to see what other people think so I have an idea what it might be. The low engine coolant light comes on but it’s full. The stop engine light comes on and shuts me down. It’s always something! ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-30 20:31:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"could be injector cup/s or cracked head\neither way, better get it in","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-12-30 20:51:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"It sounds like injector cups ","replyToPid":0}
发表于 2019-12-30 22:59:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can go to auto parts store. buy test strips. that will tell you if you got blowed head gasket. strips will change color","replyToPid":0}
 楼主| 发表于 2020-1-1 06:07:04 来自手机 | 显示全部楼层
688068 发表于 2019-12-31 01:31:08 most likely a injector cup.
","text":"It is, thanks. 3700 bucks worth, nice way to start the year lol. ","replyToPid":293841}
发表于 2019-12-30 20:30:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"dude, take it to shop and get it fixed.","replyToPid":0}
发表于 2019-12-31 09:31:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"most likely a injector cup.","replyToPid":0}
发表于 2019-12-30 23:10:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sounds like a blown head gasket. I had the same problem on my personal vehicle. Gasoline mixed in with the coolant and a trouble code of a misfire on #1 cylinder. ","replyToPid":0}
发表于 2019-12-31 09:21:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"In my country we set it on fire and roll down yuge hill.","replyToPid":0}
发表于 2019-12-31 09:31:43 来自手机 | 显示全部楼层
618279 发表于 2019-12-31 01:21:40 In my country we set it on fire and roll down yuge hill.
","text":"aren't you usually still in the vehicle when it blows up??? lmao","replyToPid":293821}
 楼主| 发表于 2019-12-30 21:14:41 来自手机 | 显示全部楼层
780067 发表于 2019-12-30 12:31:16 could be injector cup/s or cracked head\neither way, better get it in
","text":"Thanks, I appreciate your input. ","replyToPid":293272}
 楼主| 发表于 2019-12-30 21:15:16 来自手机 | 显示全部楼层
295387 发表于 2019-12-30 12:51:04 It sounds like injector cups
","text":"Thanks for the advice, I appreciate it. ","replyToPid":293283}
GMT+8, 2026-4-18 05:14 , Processed in 0.098944 second(s), 24 queries .
