查看: 71|回复: 1
Looking for mechanical advice
 楼主| 发表于 2019-12-30 19:33:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"Any driver/mechanics have a idea why there’s a diesel smell in the antifreeze? I know it can’t be right but just wanting to see what other people think so I have an idea what it might be. The low engine coolant light comes on but it’s full. The stop engine light comes on and shuts me down. It’s always something! ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-1-2 12:35:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"bad  injector, cracked piston liner, bad/blown head gasket could be a number of things.  Need to check if you are building pressure in coolant system and you can use a digital thermometer to check the temperature of each cylinder to help determine the issue, just point it at side of the engine right next to each exhaust port, if bad or dead cylinder you'll know right away","replyToPid":0}
GMT+8, 2026-4-17 15:58 , Processed in 0.108493 second(s), 24 queries .
