查看: 208|回复: 11
Will 50mph gust winds be able to roll me over with a 30,000lb load while parked?
 楼主| 发表于 2019-12-30 14:07:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"I honestly have always avoided the weather conditions before grabbing a load. But this time they screwed up our appointment time and we are stuck in the area where there is a severe conditions. So here we are parked at the truck stop and man we are shaking. And unfortunately there is no parking next to the building. So anyone knows if there is a possibility to be rolled over standing still at such conditions?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-30 14:53:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Track the direction of the wind, put your head opposite of that. When you roll you won't hit your head.","replyToPid":0}
发表于 2019-12-30 20:32:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"I see that these trucking schools are teaching you guys so well. 🤦‍♂️ \n","replyToPid":0}
发表于 2019-12-31 00:21:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Your total weight is around 60 you are fine even empty. ","replyToPid":0}
发表于 2019-12-31 04:40:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"put the nose or rear facing into the wind","replyToPid":0}
 楼主| 发表于 2019-12-31 09:19:16 来自手机 | 显示全部楼层
626560 发表于 2019-12-30 06:53:53 Track the direction of the wind, put your head opposite of that. When you roll you won't hit your head.
","text":"Yeah, unfortunately the wind went different ways it was pretty crazy. ","replyToPid":293213}
发表于 2019-12-31 08:27:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"You're safe parked.  Keep in mind that all the other trucks in the lot will help block the wind.\n\nEven driving with a 30k load shouldn't have 50mph gusts roll you, but it can make you fight to stay in your lane.  Could make you slide on snow though.","replyToPid":0}
发表于 2019-12-30 22:44:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"I always tried parking between other trucks on windy days","replyToPid":0}
发表于 2019-12-30 14:25:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"50mph sustained winds, shouldn't be able to no. They are going to shake, and rattle you. But not roll you.","replyToPid":0}
 楼主| 发表于 2019-12-31 09:20:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"But thank you everyone for your kind responses. There were just a couple of times I really thought we would be on the side 🤦🏼‍♀️","replyToPid":0}
GMT+8, 2026-2-16 11:05 , Processed in 0.056119 second(s), 24 queries .
