查看: 206|回复: 8
I have a canadian friend who asked me this
 楼主| 发表于 2019-12-30 03:11:00 来自手机 | 显示全部楼层 |阅读模式
{"text":"\"Tthe MOT gives us 13 hours of drive time per day, if I cross into the US will my ELD update to DOT and give me only 11 hours or will it continue to let me drive for 13?\" ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-30 09:06:19 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"you could technically start the pretrip the day prior and have it end right at 12:01am.  That just leaves the half hour break.  11 hours + 30 min break, 10 hour break.  21.5 hours.  Start post trip at 11:59pm.\n\nEnd up with 13 hours 28 mins legal drive time.  Couldn't do it daily though."}
发表于 2019-12-30 03:47:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"When you cross into USA you must switch your eld over to USA. Also you will be restricted to the USA dot laws. ","replyToPid":0}
发表于 2019-12-30 18:01:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Throw that ELD stuff in a trash and drive","replyToPid":0}
发表于 2019-12-30 08:49:34 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If you perform a pre trip at 12am in the morning you do not need a 2nd pre trip when you get back on the road unless it's the next day, but since you want to get technical I guess it's 13 hours of drive time regardless if you're in the states or far north"}
发表于 2019-12-30 06:59:17 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"you can actually drive 14 hours a day in the states if you drive 11 hours shut down and then get right back on the road at the end of your 10"}
发表于 2019-12-30 07:42:14 来自手机 | 显示全部楼层
724453 发表于 2019-12-29 22:59:17 you can actually drive 14 hours a day in the states if you drive 11 hours shut down and then get right back on the road at the end of your 10
","text":"Actually that’s not true anymore. You have post trip inspection and pretrip inspection then the 30 min break. ","replyToPid":292976}
发表于 2019-12-30 12:09:57 来自手机 | 显示全部楼层
280160 发表于 2019-12-30 01:06:19 you could technically start the pretrip the day prior and have it end right at 12:01am.  That just leaves the half hour break.  11 hours + 30 min break, 10 hour break.  21.5 hours.  Start post trip at 11:59pm.\n\nEnd up with 13 hours 28 mins legal drive time.  Couldn't do it daily though.
","text":"I would run like that when I was on recap hours on the company side and if I had to take a 34 I would make sure I was shut down before 1:30pm so I could get back on the road the next day","replyToPid":293058}
发表于 2019-12-31 10:01:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"When in Rome......","replyToPid":0}
GMT+8, 2026-4-18 05:14 , Processed in 0.075113 second(s), 24 queries .
