查看: 121|回复: 7
Feds double number of truckers to get drug tests
 楼主| 发表于 2019-12-29 03:37:51 来自手机 | 显示全部楼层 |阅读模式
{"text":"The new year will begin with it a new demand by the federal government to test more truckers for alcohol and drug use.\n\nCurrently, 25% of all truckers must be tested. But, results from a 2018 survey have triggered a requirement that doubles that amount to a minimum of 50% of a carrier’s total number of drivers. That survey found the number of truckers that tested positive for controlled substances had increased to 1%, and that caused the testing increase for 2020.\n\nRead more: https://www.truckersnews.com/feds-double-number-of-truckers-to-get-drug-tests/  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-29 11:07:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"God forbid a grown a$$ man smokes a joint in the evening. ","replyToPid":0}
回复 支持 4 反对 1
发表于 2019-12-29 14:02:30 来自手机 | 显示全部楼层
861197 发表于 2019-12-29 03:07:11 God forbid a grown a$$ man smokes a joint in the evening.
","text":"That's the gateway drug tho!","replyToPid":292379}
发表于 2019-12-29 23:23:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"4th amendment: The right of the people to be secure in their persons, houses, papers, and effects, against unreasonable searches and seizures, shall not be violated, and no Warrants shall issue, but upon probable cause, supported by Oath or affirmation, and particularly describing the place to be searched, and the persons or things to be seized.","replyToPid":0}
发表于 2019-12-29 23:11:54 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Only one time in 20 years have I ever had a breathalyzer done during a drug test. I’ve been randomly tested at least 15 times and pre employment  tested 3 times.  Why is legal to have a Bar in a truck stop? Why do 90% of truck stops sell beer? Random drug  testing is not a fair or just practice! It’s a flat out invasion of privacy! \nGuilty until you prove yourself innocent is the new American way. "}
发表于 2019-12-29 21:02:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"But feel free to drink at the truck stop and drive the next morning hungover 😵 ","replyToPid":0}
发表于 2019-12-29 21:01:03 来自手机 | 显示全部楼层
622590 发表于 2019-12-29 06:02:30 That's the gateway drug tho!
","text":"No alcohol is. ","replyToPid":292461}
发表于 2019-12-29 11:00:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"meh. no concern here","replyToPid":0}
GMT+8, 2026-2-6 14:04 , Processed in 0.057926 second(s), 24 queries .
