查看: 503|回复: 13
Where did the drum go? anyone ever seen anything like this?
 楼主| 发表于 2019-12-28 01:49:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1838.0,\"name\":\"\",\"url\":\"\",\"width\":842.0},{\"description\":\"\",\"height\":1924.0,\"name\":\"\",\"url\":\"\",\"width\":881.0}]","canComment":true,"externalShare":false}
发表于 2019-12-31 11:25:56 来自手机 | 显示全部楼层
370859 发表于 2019-12-27 17:50:43 U should had done a pre trip done buddy,  before u starts rolling . Must b not oil in the axles are u knew driver ?
","text":"oil in the axles has NOTHING to do with the brake drum....lmfao","replyToPid":291410}
回复 支持 6 反对 0
发表于 2019-12-28 01:50:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"U should had done a pre trip done buddy,  before u starts rolling . Must b not oil in the axles are u knew driver ? ","replyToPid":0}
 楼主| 发表于 2019-12-28 01:52:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"no. not new. the drum was there during pretrip. a small crack will split it with one push of the brakes since it's cast iron","replyToPid":0}
发表于 2019-12-28 01:51:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Or got ur license in Florida ? 🤦🏽‍♂️🤷🏽‍♂️🤷🏽‍♂️","replyToPid":0}
发表于 2019-12-28 04:18:05 来自手机 | 显示全部楼层
884942 发表于 2019-12-27 17:52:18 no. not new. the drum was there during pretrip. a small crack will split it with one push of the brakes since it's cast iron
","text":"B safe brother and happy New Years 💰🙏🏽🙏🏽🙏🏽 I hope u do make that up 💰","replyToPid":291414}
发表于 2020-1-3 14:25:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Brake drum was worn out... pressure when brakes applied... BOOM 💥 ","replyToPid":0}
发表于 2019-12-31 11:24:59 来自手机 | 显示全部楼层
","text":"are you new to English?","replyToPid":291410}
发表于 2019-12-31 11:24:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"shattered...","replyToPid":0}
发表于 2020-1-3 01:54:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’d think the mechanic never put it back on lol but I guess shattered cast iron can break like that. Was the rim tight on the hub?","replyToPid":0}
GMT+8, 2026-4-17 00:22 , Processed in 0.129810 second(s), 24 queries .
