查看: 150|回复: 8
governed truck?
 楼主| 发表于 2019-12-27 10:57:36 来自手机 | 显示全部楼层 |阅读模式
{"text":"is there a way to make your truck show that it's governed when it isn't? there's some decent loads coming out of canada to NY but I'm not trying to govern my truck for real","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-27 20:47:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I got yer decent loads!!","replyToPid":0}
发表于 2019-12-27 19:24:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Could probably show 65mph on a small tire/rear end ratio.  Speedometer will show one speed, but the final ratio should probably push it a bit faster.","replyToPid":0}
发表于 2019-12-27 13:11:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take your truck to diesel doctor have them adjust how governed your truck is,  and can even program in a hidden file in the tune where you're ungoverned.","replyToPid":0}
发表于 2019-12-28 12:59:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just put a “b” model in it and hammer down! ","replyToPid":0}
发表于 2019-12-28 01:45:23 来自手机 | 显示全部楼层
724453 发表于 2019-12-27 05:16:37 I'm not governed at all but in order to cross into Canada you need to be governed at 65 or less, I'm just looking for something that makes their reader see \"governed at 65mph\" without actually governing the truck
","text":"not if you're american. I'm in canada frequently with a truck governed at 71.","replyToPid":291171}
 楼主| 发表于 2019-12-28 01:41:47 来自手机 | 显示全部楼层
861197 发表于 2019-12-27 12:47:41 I got yer decent loads!!
","text":"I see what you did there 😂😂","replyToPid":291256}
 楼主| 发表于 2019-12-27 13:16:37 来自手机 | 显示全部楼层
595611 发表于 2019-12-27 05:11:32 Take your truck to diesel doctor have them adjust how governed your truck is,  and can even program in a hidden file in the tune where you're ungoverned.
","text":"I'm not governed at all but in order to cross into Canada you need to be governed at 65 or less, I'm just looking for something that makes their reader see \"governed at 65mph\" without actually governing the truck","replyToPid":291162}
 楼主| 发表于 2019-12-27 13:16:13 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I don't need to remove a governor"}
GMT+8, 2026-2-16 19:52 , Processed in 0.053919 second(s), 24 queries .
