查看: 224|回复: 9
What's up stretching a tractor out like this?
 楼主| 发表于 2019-12-27 10:25:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":720.0,\"name\":\"\",\"url\":\"\",\"width\":960.0}]","canComment":true,"externalShare":false}
发表于 2019-12-27 22:39:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"alot better ride","replyToPid":291230}
发表于 2019-12-28 07:33:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can jackknife more than 90 degrees angle without damaging the cab","replyToPid":291230}
发表于 2019-12-27 12:57:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Looks cool 😎 they think until they get in a tight spot ","replyToPid":0}
发表于 2019-12-27 15:14:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Something about a desire to unbolt that tiny sleeper to put a bigger sleeper behind it.","replyToPid":0}
发表于 2019-12-27 16:15:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"it has more advantages than you think compared to regular semitruck","replyToPid":0}
发表于 2019-12-27 19:02:53 来自手机 | 显示全部楼层
84882 发表于 2019-12-27 08:15:54 it has more advantages than you think compared to regular semitruck
","text":"such as?","replyToPid":291216}
发表于 2019-12-27 19:30:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only advantage I see is a longer distance away from the noisy reefer.  The downfall is the aerodynamics are screwed, not even an air dam installed.","replyToPid":0}
发表于 2019-12-28 18:50:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Jus put a trailer in the truck ","replyToPid":0}
发表于 2019-12-30 07:52:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"4 mpg 😆 ","replyToPid":0}
GMT+8, 2026-4-19 02:50 , Processed in 0.092620 second(s), 24 queries .
