查看: 222|回复: 16
Automatic vs Manual
 楼主| 发表于 2019-12-27 09:24:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"Ok drivers, I need your help with some info. is it true that trucks with automatic transmission have a better fuel economy? I'm in the market to buy a truck. I love the 13 speed but I've been hearing that trucks with automatic are better when it comes to fuel economy. what's your thoughts on that guys. any info will help. Thank you. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-27 21:28:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"I hate automatics in snow and ice, but they’re great for other things.  ","replyToPid":0}
发表于 2019-12-27 14:49:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s hard to get use to it. But it’s great once you do. The fuel economy is way better with the automatic. The new system freightliner has 12 speed economy mode puts your truck in neutral when cresting a hill and going down basically riding the hill down which saves a ton of fuel right there. Then being it’s automatic it has a computer doing the shifting at the correct rpm to not waste fuel. \n\nTell you what it’s great in traffic. They even fixed the gap between shifting. They also made it to stay at current speed in reverse so it’s much easier now not to slam into docks like it was. Also it’s like a car where you release brake in traffic truck starts rolling doesn’t have to shift into gear. ","replyToPid":0}
 楼主| 发表于 2019-12-27 22:17:10 来自手机 | 显示全部楼层
767688 发表于 2019-12-27 13:28:29 I hate automatics in snow and ice, but they’re great for other things.
","text":"I was thinking about that too, I never drove an automatic on snow before. I drove manual and i feel i can have a better control of the truck. maybe I'm wrong but that's how I feel. but it is something for me to think about. thank you for pointing it out.","replyToPid":291279}
发表于 2019-12-29 14:11:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"You should have done your research before asking this question.   \n\nIf you have to ask, don't buy a truck.","replyToPid":0}
发表于 2019-12-28 06:40:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"auto is the way to go  your knee will thank you","replyToPid":0}
发表于 2019-12-28 01:22:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Most if not all automatics have a manual mode were you can shift the gears as if your in a manual shift truck.","replyToPid":0}
发表于 2019-12-27 14:18:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes they're rated higher fuel economy, especially the newer freightliner, the cruise control is adaptive based on terrain. They have an base fuel economy of 9.8mpg, the same truck in manual are at 7mpg or lower.","replyToPid":0}
 楼主| 发表于 2019-12-27 21:14:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you guys for the info. I really appreciate it.","replyToPid":0}
发表于 2019-12-28 03:40:54 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"There is a major drawback on the 2020 Eaton automatics though. We have been seeing major software glitches. I have been through 3 this year. 2 Cascadias and an International. Each one had similar problems with the computers losing it between gears. One failed completely to the point it and the ECU stopped communicating. Truck forgot it had a transmission! If you check the news, maintenance issues kill a number of companies this year. Number one was DEF/emissions issues. Number two with a bullet to your head was automatic transmission issues. Fuel mileage can be better with them. I can't stand 2 and 3 week shop times when they fail."}
发表于 2019-12-28 08:21:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"check the mpg specs on the new Mack Anthem,  and the new Western Star. they have amazing features built into the transmission system.","replyToPid":0}
GMT+8, 2026-2-16 16:48 , Processed in 0.150554 second(s), 24 queries .
