查看: 178|回复: 15
Why do people don't like fords?
 楼主| 发表于 2019-12-26 09:07:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"This one looks nice.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":720.0,\"name\":\"\",\"url\":\"\",\"width\":960.0}]","canComment":true,"externalShare":false}
发表于 2019-12-26 09:50:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ford is the ONLY brand of vehicle I’ve owned that hasn’t been a constant headache. ","replyToPid":0}
回复 支持 2 反对 2
发表于 2019-12-26 09:20:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have 3 fords there the best own by Americans to ","replyToPid":0}
发表于 2019-12-27 03:40:10 来自手机 | 显示全部楼层
157862 发表于 2019-12-26 18:53:19 Personal experience says I’d rather walk.  I’m going to anyway, why drop tens of thousands on the way?\n\nFriend swears by fords, yet can’t explain why he prefers them - after dropping $12,000 plus into repairs for oil leaks and camshaft problems on two well cared for pickups- to his Dakota, which hasn’t had an issue in 4 years
","text":"did you know gm frames are still wax coated instead of e-coated like ford and ram do?  bet not.","replyToPid":290873}
发表于 2019-12-27 02:53:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Personal experience says I’d rather walk.  I’m going to anyway, why drop tens of thousands on the way?\n\nFriend swears by fords, yet can’t explain why he prefers them - after dropping $12,000 plus into repairs for oil leaks and camshaft problems on two well cared for pickups- to his Dakota, which hasn’t had an issue in 4 years","replyToPid":0}
发表于 2019-12-27 00:55:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Newer models maybe okay, but doing a certain time frame (late 90s-mid 2000s) a particular recall was issued for Fords that had a Triton engine underneath. Spark plugs (literally) blew out from the engine & costing thousands to repair. Even though the engine needed to be rethreaded for said plugs to go back into place, the fact that Ford knew about the potential issue, they didn't openly issued the recall until they came out w/ a new engine size for newer trucks & just lazily put it in middle of a magazine story as like nothing happened.","replyToPid":0}
发表于 2019-12-27 00:53:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"actually Ford motorcraft oil is an excellent oil","replyToPid":0}
发表于 2019-12-26 23:54:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"CHEVROLET is the way to go they look so much nicer with a lift and a set of 35's","replyToPid":0}
发表于 2019-12-26 09:56:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"That’s probably a 70k truck","replyToPid":0}
发表于 2019-12-26 11:37:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"they nice trucks both the company invest money on anticonstitucional organizations and I don't support nothing that have nothing to do against my constitution..\nI don't buy for target, ford, and other companies that is against my constitution","replyToPid":0}
发表于 2019-12-26 12:27:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have a friend with 2018 f150 with a 5L and 25000miles engine seized last week prob the shit oil they use at dealership not only that they have had many recalls recently not too sure if i would trust the new trucks ","replyToPid":0}
发表于 2019-12-26 12:28:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have a friend with 2018 f150 with a 5L and 25000miles engine seized last week prob the oil they use at dealership not only that they have had many recalls recently not too sure if i would trust the new trucks ","replyToPid":0}
发表于 2019-12-26 18:59:18 来自手机 | 显示全部楼层
864562 发表于 2019-12-26 04:27:50 Have a friend with 2018 f150 with a 5L and 25000miles engine seized last week prob the shit oil they use at dealership not only that they have had many recalls recently not too sure if i would trust the new trucks
","text":"Did he change oil or did run out of oil?","replyToPid":290756}
发表于 2019-12-26 18:59:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did he change oil or did run out of oil?","replyToPid":0}
GMT+8, 2026-2-14 00:22 , Processed in 0.087697 second(s), 24 queries .
