查看: 92|回复: 5
Are the current HOS rules enough for you?
 楼主| 发表于 2019-12-23 04:35:14 来自手机 | 显示全部楼层 |阅读模式
{"text":"Should they change it?  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-23 14:10:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"boy this topic can explode in a second.... the hours of service are flawed. No room for common sense,  and instead of encouraging safe driving.  All it does is force drivers to speed and be in a hurry. I say throw it out as well as the elogs. There's nothing safe about either regulation.  You can try to argue,  but you'll be wrong.. lol","replyToPid":0}
发表于 2019-12-23 05:55:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can drive up to 14 hours a day if you work it right the 30 minute break has to go though","replyToPid":0}
发表于 2019-12-23 15:16:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just get rid of the continuous 14 hour clock is enough for me.","replyToPid":0}
发表于 2019-12-24 00:43:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"We need some kind of clock, if not Dispatcher and companies will take more advantage of us. It just needs to be reworked. Some How. ","replyToPid":0}
发表于 2019-12-24 02:14:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"The old way was not perfect but it worked a hell of a lot better. 10 drive - 8 rest. And you could stop your clock after you started it.","replyToPid":0}
GMT+8, 2026-2-17 04:53 , Processed in 0.071099 second(s), 25 queries .
