查看: 536|回复: 34
After your 10hrs of driving do you have to spend spend the rest of the time in the cab?Can you venture outside the cab?
 楼主| 发表于 2019-12-23 00:51:07 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-12-23 01:44:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"nope, you're locked in the truck, hope you have a toilet or diapers \n\nseriously though, you can get out and do stuff.  Keep in mind that 10 hour break includes sleeping.  But if you have extra time to kill there is no harm in exploring.  There are rest areas and truck stops with trails or close to parks.  There are some that are close to museums or zoo's too.\n\nMississippi Welcome Center (i10, exit 2) is right next to the Infinity Space Center.  Park, walk over and see the museum, get a bus tour of the John C Stennis Space Center.\n\nIf you're near Atlanta Georgia, there is a small truck stop off i75 exit 293.  Tellus Science Museum is right behind it.\n\ni80 in Wyoming right at the Nebraska boarder, the Wyoming Welcome Center has a few miles of trails behind it that take you up onto the plateaus which offer panoramic views of the surround flat land.  You can see for miles.\n\ni8 in California, exit 51 rest area.  There is a 4x4 trail that goes up the mountain right at the off ramp.  If you're ok with walking uphill for 3 miles you get a great view.  Trail is over 10 miles long if I recall correctly.\n\ni40, exit 9 in Arizona.  The Pilot truck stop has a dirt road into the desert behind it.  Go exploring but take your phone so you don't get lost.\n\ni80 through Utah has a rest area in the middle of the salt flats.  Park and take a walk.  Couple dozen square miles of flat wide open bright white land.  No fences, hardly any roads, no shade.  Walk a mile out and there is nothing but silence.  It's where they filmed Jack Sparrow in Davey Jones Locker in Pirates of the Caribbean At Worlds End.","replyToPid":0}
回复 支持 5 反对 1
发表于 2019-12-23 01:53:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"what's with all the dumb @$$ posts","replyToPid":0}
发表于 2019-12-23 01:27:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"only if you are going to vote for trump","replyToPid":0}
发表于 2019-12-28 07:41:34 来自手机 | 显示全部楼层
877513 发表于 2019-12-23 01:40:21 Thank you, it did. I realize that this is a unusual question for a veteran trucker. I'm going to CDL School in 2 weeks after 30 years in Corporate America. I've been off for a couple weeks and I think about things regarding my new career. I'm an avid gym rat and am trying to figure out how and when I can workout ( Planet Fitness) when OTR. 😁
","text":"You find time during your 14 hours duty day when possible. Your 10 hour break can be used for gym time, so can the 30 min. lunch break. I also use load and unload time if I am permitted to be outside of my truck (per customer policy).  Get a jump rope and a yoga map. Free weight time will be premium.","replyToPid":289355}
发表于 2019-12-23 09:54:26 来自手机 | 显示全部楼层
877513 发表于 2019-12-23 01:37:55 Thank you, it did. I realize that this is an unusual question for a veteran trucker. I'm going to CDL School in 2 weeks after 30 years in Corporate America. I've been off for a couple weeks and I think about things regarding my new career. I'm an avid gym rat and I'm  trying to figure out how and when I can workout ( Planet Fitness) when OTR. 😁
","text":"The good ol rules and regs can be confusing. It's good you're asking questions ahead of time. If you'll be running e-logs, most programs alert you to what you need to do and when as far as hours between breaks and the like. Just always take the time to plan your route and add time for unforeseen delays. And don't rely on what time any given mapping app may tell you on how far you maybe able to in x-amount of hours. Get out the good old paper atlas and compare the various routes so you have a backup plan. Remember that a lot of your truck stops on major routes fill up a little more early than on secondary highways, in other words, don't think \"oh I can make 650 miles today and stop at this place for my off duty hours\"  it could be full, so think ahead and stop early if need be. It's easy once you get the hang of it. But please remember, don't always rely on the darn apps to get you around. Compare them to an actual truckers road atlas and give yourself some plans. Good luck","replyToPid":289352}
发表于 2019-12-23 07:05:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"You are trapped for 10 hours. No getting out, no restroom, nothing.\n\nBut seriously, the rule basically states that you must have a total of 10 hours off. At least 2 hours of that 10 must be logged as Off Duty, Not driving. The other 8 must be logged as consecutive hours under Sleeper Berth. (If you're a day cab and stay at a motel, then the hours will all just be logged as Off Duty)\nFor example...If you park and log off, Off Duty, go shower, eat, walk around for an hour, climb in the sleeper for sleeper Berth for 8 hours, wake up, go back to 1 hour of Off Duty while you get your coffee and breakfast,and  brush your teeth like a good little trucker, then you have fulfilled your 10 hours. You can split up the 2 hours however you want to, as long as you log the 8 hours consecutively. Of course, most people obviously can not go a full 8 hours without having to use the restroom or walk around. You do not need to change you duty status just to get up and go wee in the middle of your sleeper berth hours.\n\nI hope that made sense","replyToPid":0}
 楼主| 发表于 2019-12-23 23:10:14 来自手机 | 显示全部楼层
779898 发表于 2019-12-23 14:10:40 Some truck stops have gyms and I’ve done pushups at the fuel islands while fueling, sit ups at rest areas and such. You won’t have the regular routine but you can maintain.
","text":"And most definitely make your own meals. I figure that truck stop food will kill you! 😂","replyToPid":289604}
 楼主| 发表于 2019-12-23 02:50:51 来自手机 | 显示全部楼层
103619 发表于 2019-12-22 17:53:17 what's with all the dumb @$$ posts
","text":"Goin to school in 2 weeks","replyToPid":289057}
发表于 2019-12-23 01:37:36 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"buggy app multipost"}
发表于 2019-12-23 22:10:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Some truck stops have gyms and I’ve done pushups at the fuel islands while fueling, sit ups at rest areas and such. You won’t have the regular routine but you can maintain. ","replyToPid":0}
发表于 2019-12-23 01:10:57 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"comment deleted"}
 楼主| 发表于 2019-12-23 01:38:40 来自手机 | 显示全部楼层
280160 发表于 2019-12-22 17:37:36 nope, you're locked in the truck, hope you have a toilet or diapers \n\nseriously though, you can get out and do stuff.  Keep in mind that 10 hour break includes sleeping.  But if you have extra time to kill there is no harm in exploring.  There are rest areas and truck stops with trails or close to parks.  There are some that are close to museums or zoo's too.\n\nMississippi Welcome Center (i10, exit 2) is right next to the Infinity Space Center.  Park, walk over and see the museum, get a bus tour of the John C Stennis Space Center.\n\nIf you're near Atlanta Georgia, there is a small truck stop off i75 exit 293.  Tellus Science Museum is right behind it.\n\ni80 in Wyoming right at the Nebraska boarder, the Wyoming Welcome Center has a few miles of trails behind it that take you up onto the plateaus which offer panoramic views of the surround flat land.  You can see for miles.\n\ni8 in California, exit 51 rest area.  There is a 4x4 trail that goes up the mountain right at the off ramp.  If you're ok with walking uphill for 3 miles you get a great view.  Trail is over 10 miles long if I recall correctly.
","text":"Thank you for the ONLY sane response","replyToPid":289046}
 楼主| 发表于 2019-12-23 01:39:03 来自手机 | 显示全部楼层
840756 发表于 2019-12-22 17:27:44 only if you are going to vote for trump
","text":"Guess I'm stuck in the cab..","replyToPid":289044}
发表于 2019-12-23 01:45:52 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"buggy app multi post"}
发表于 2019-12-23 02:17:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"yup just you have to stay in your truck!! the rest of us are grown a** adults that can make our own decisions","replyToPid":0}
GMT+8, 2026-4-17 10:13 , Processed in 0.085903 second(s), 24 queries .
