查看: 345|回复: 14
PC
 楼主| 发表于 2019-12-21 21:21:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"How many miles can we go personal conveyance safe place to park?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-22 11:47:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Advance the load within reason, if there are 2 truck stops about the same distance away and one is on the way I’m going and one is the opposite direction I will always go the way I’m going. Write me up all you want I don’t care. Some regulations are just idiotic. Use common sense and just get to a safe place to park within reason. There’s no one size fits all with this question. What if you’re in a remote area and the nearest place to park is 80 miles away, use all 80 miles. You’re pretty much at the mercy of the situation and dot. I’ve never had a dot officer nit pick every stop like that though. That’s crazy ","replyToPid":0}
发表于 2019-12-21 21:25:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"use the search feature this question has been asked 100 times","replyToPid":0}
发表于 2019-12-22 00:33:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Need more information.\nBobtailing or with trailer?\nTrailer loaded or empty?\nWhat country?\n\nAll these factors, among others, determine the answer.","replyToPid":0}
发表于 2019-12-21 22:11:12 来自手机 | 显示全部楼层
发表于 2019-12-21 22:19:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"40 miles or 45 min based on dot","replyToPid":0}
 楼主| 发表于 2019-12-22 03:33:23 来自手机 | 显示全部楼层
310244 发表于 2019-12-21 16:33:03 Need more information.\nBobtailing or with trailer?\nTrailer loaded or empty?\nWhat country?\n\nAll these factors, among others, determine the answer.
","text":"With a load?","replyToPid":288442}
发表于 2019-12-22 05:54:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can’t use that feature if you are on a load. If you run into bad weather/accident, there should be another option for you on your ELD. ","replyToPid":0}
发表于 2019-12-23 10:20:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nearest location you can find or just unplug and do as you please.. edit later.","replyToPid":0}
发表于 2019-12-23 17:54:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"last week I got stuck in Seattle traffic, had to use for over an hour looking for parking.","replyToPid":0}
GMT+8, 2026-4-19 02:49 , Processed in 0.134845 second(s), 24 queries .
