查看: 930|回复: 25
Why does this happen on hills ? Btw this is I 84 going to Connecticut
 楼主| 发表于 2019-12-20 13:11:49 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[{\"url\":\"http://d2w8udw005hdju.cloudfront.net/video/228896/ios_618559_1576818651497.mp4\"}]","link":"{}","pics":"[{\"description\":\"\",\"height\":345.0,\"name\":\"\",\"url\":\"\",\"width\":200.0}]","canComment":true,"externalShare":false}
发表于 2019-12-20 13:42:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"And being a tool running your brights on. ","replyToPid":0}
回复 支持 15 反对 0
发表于 2019-12-20 13:23:07 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"What am I looking for here? Other than you illegally handling your phone while driving? "}
回复 支持 13 反对 1
发表于 2019-12-20 14:33:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"looks like you're almost out of gas and you're running your brights onto everybody. put  the phone down, turn off your brights and go fuel up.","replyToPid":0}
回复 支持 10 反对 0
发表于 2019-12-25 02:19:46 来自手机 | 显示全部楼层
576904 发表于 2019-12-21 08:24:19 ok.... serious reply...just incase you don't know.... what's your gear ratio?\nhow heavy? what's the grade? if you have a \"highway\" gear ratio.... when climbing drop your speed, lower your RPM's....try climbing at about 20 mph (30kph)...keep your RPM's around 1400 ish... you'll be down in 5 low if you're running a standard tranny..... it's not a race! \npushing that hard is hard on the truck....you'll wear our your rearends faster, your tires faster, you'll burn less fuel.... etc etc.... be nice to your truck and she'll be nice to you... and yes, turn off your high beams......just sit back, enjoy the ride up those hills. Patience, Driver, patience. oh yes, and when climbing in warmer weather, turn off your AC or you'll cook the motor, literally. climbing slow will keep the heat down...... that truck will climb all day long if ya take it easy. \n\ncheers!
","text":"🙏 agree on every point.","replyToPid":288321}
发表于 2019-12-20 16:41:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"2500 RPM’S??? 😆 ","replyToPid":0}
发表于 2019-12-20 15:19:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'd say something, but y'all beat me to it 😂😂😂\nif your asking why another trucker can pass you.\nhonestly.. if ya are asking...you seriously need not to be in this industry\ncommand sense plays a huge part in your ability to drive, as a professional.. and know the answer , already 😉😁😎😂😂😂🤫","replyToPid":0}
发表于 2019-12-20 23:01:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've heard that if you paint the engine yellow you can be the one passing, I'm not sure though it's just what I've been told.","replyToPid":0}
发表于 2019-12-21 16:24:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"ok.... serious reply...just incase you don't know.... what's your gear ratio?\nhow heavy? what's the grade? if you have a \"highway\" gear ratio.... when climbing drop your speed, lower your RPM's....try climbing at about 20 mph (30kph)...keep your RPM's around 1400 ish... you'll be down in 5 low if you're running a standard tranny..... it's not a race! \npushing that hard is hard on the truck....you'll wear our your rearends faster, your tires faster, you'll burn less fuel.... etc etc.... be nice to your truck and she'll be nice to you... and yes, turn off your high beams......just sit back, enjoy the ride up those hills. Patience, Driver, patience. oh yes, and when climbing in warmer weather, turn off your AC or you'll cook the motor, literally. climbing slow will keep the heat down...... that truck will climb all day long if ya take it easy. \n\ncheers!","replyToPid":0}
发表于 2019-12-22 11:23:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"wow either shift up or back off the accelerator those rpms are making me cringe over here","replyToPid":0}
发表于 2019-12-21 04:15:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"First thing I noticed.... high beams n high rpms🤦🏻‍♂️🤦🏻‍♂️","replyToPid":0}
发表于 2019-12-20 15:38:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Oh LAWD, he commin ","replyToPid":0}
发表于 2019-12-20 19:00:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah?! He’s gonna blow that motor if he keeps that up. ","replyToPid":287540}
发表于 2019-12-20 19:00:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah?! He’s gonna blöw that motor if he keeps that up. ","replyToPid":0}
GMT+8, 2026-3-21 06:10 , Processed in 0.113760 second(s), 24 queries .
