查看: 69|回复: 1
apartments handyman left this in my apartment after doing the floor
 楼主| 发表于 2019-12-20 10:22:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"I guess it's what holds the floor tile to the floor","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1632.0,\"name\":\"\",\"url\":\"\",\"width\":1224.0}]","canComment":true,"externalShare":false}
发表于 2019-12-20 14:03:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"No. Linoleum flooring is held down with a special adhesive. That’s just grout caulk. You use it to fill crack and hard lines that water could seep through. Probably between your sink and the counter to stop water from going under and into the cabinet ","replyToPid":0}
GMT+8, 2026-2-16 02:30 , Processed in 0.055803 second(s), 24 queries .
