查看: 82|回复: 5
Do you think, Can a cop pull you over for reckless driving on private property?
 楼主| 发表于 2019-12-20 09:43:55 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-12-20 12:06:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"If it's in a area like a strip mall or similar, yes.  If it's on like rural property, (not yours), yes if there is a complaint. Otherwise, if it's on property you own, most likely not unless there an accident with injuries ","replyToPid":0}
发表于 2019-12-20 12:37:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depends on whether or not you pull over","replyToPid":0}
发表于 2019-12-20 12:24:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"No..why would they be on a private property at 1st place?","replyToPid":0}
发表于 2019-12-20 15:39:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Give me forty acres and I’ll turn this truck around sir","replyToPid":0}
发表于 2019-12-20 18:02:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Navy Gator nailed it.","replyToPid":0}
GMT+8, 2026-2-17 02:56 , Processed in 0.060494 second(s), 24 queries .
