查看: 101|回复: 2
waking up with no air on my tractors breaking system.
 楼主| 发表于 2019-12-20 09:33:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"so for the last couple of days my 2018 freightliner cascadia has been loosing air everytime i wake up from my 10 hour break. i have sat down at a couple of places and inspected my truck for air leaks to no avail. someone told me this new trucks have an auto draining system that drains the air from the tanks to keep them from building moister and causing break problems. so i just wanted to hear from yall more experience drivers.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-29 13:09:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Mine doesnt hold air for more than a few hours, i find a leak i fix it then it will start leaking somewhere else... But if your truck is holding air for a few hours and you don't loose pressure when doing a break check i wouldn't worry about it. ","replyToPid":0}
发表于 2020-1-7 08:47:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"use simple green and spray around your air lines and fittings if there is a leak it should bubble up.","replyToPid":0}
GMT+8, 2026-4-17 15:57 , Processed in 0.099516 second(s), 24 queries .
