查看: 372|回复: 21
Need inverter advice.
 楼主| 发表于 2019-12-19 12:11:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"So my wife and I are huge gamers and we are also team drivers. Our boss won’t allow an inverter to be wired to the battery so I’m wondering if anyone can give me advice on how to run a Xbox one x and a 30” hd tv through the 12v cigarette lighter plugs. My thoughts are buying two 300w pure sine wave inverters and plugging them into separate 12v plug ins, and running tv on one and Xbox on the other. Will this work?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-19 15:38:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Basically your boss is telling y'all to grow up an drive!!!!","replyToPid":0}
回复 支持 4 反对 3
发表于 2019-12-19 22:59:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Drivers, I will get straight to it.  \n\nWe have a minimum quality of life out here. And when I say this I refer to having a power source to use for the simple things that should be experienced of your a company Driver. \n\n Tv, Microwave, toaster oven, gaming consoles, crockpots, coffee pots, computet, laptops, tabs, Cpap if you should need, I could go on. \n\nBut the simple fact is that the owner of truck should provide a invertor willingly for you and you wife to have a quality of life one should expect. \n\nSo my advice, find another truck to get into and leave your current employer if at all possible. \n\nI know of a few Companies that will pick you up if you should need some help.\n\nYour truck is your home and your employer should  do everything to accommodate you and your wife. \n\nCheers!!\n\"Protect yourself AND Your CDL\"","replyToPid":0}
发表于 2019-12-19 23:02:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Side note. \n\nSorry for grammatical errors. I was livid for the simple fact that your employer is doing this. \n\nCheers!!\n\"Protect yourself AND Your CDL\"","replyToPid":0}
发表于 2019-12-20 05:17:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you drive for someone who won't allow an inverter in the truck, then you're already a better driver than they deserve. Just my .02","replyToPid":0}
发表于 2020-5-25 13:53:12 来自手机 | 显示全部楼层
211886 发表于 2020-01-23 05:30:46 Wondering why someone disagreed with the down arrow.\nLemme guess... A company driver who gets a call from his dispatcher 1 minute after his 10 hour break is up.\nYea, you keep on truckin driver... Don't worry, some day you may understand...
","text":"just put a small gas generator on the cat walk strap it down,run extension cord and hit the road,since your company wont allow an inverter.","replyToPid":310805}
发表于 2020-1-23 13:05:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Notfanuthin, but... Why grow up?\nYou only get one life... Enjoy it.\nI have an Xbox and flat-screen TV, and all the other creature comforts in here.\nI drive when I want to, take off whenever I feel like it and it's sometimes for weeks.\nJust because, for the most part, we live in our trucks, doesn't mean we shouldn't enjoy our downtime.\nI drive nights (8 hours a night ) which gives me a lot more time off then most drivers.\nAnd I watch TV and play my games.\nAnd sometimes talk to you people.","replyToPid":0}
发表于 2020-5-25 19:24:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Gamers?  Get outside and exercise you fat slobs ","replyToPid":0}
发表于 2020-1-23 12:58:42 来自手机 | 显示全部楼层
626560 发表于 2019-12-19 14:59:36 Drivers, I will get straight to it.  \n\nWe have a minimum quality of life out here. And when I say this I refer to having a power source to use for the simple things that should be experienced of your a company Driver. \n\n Tv, Microwave, toaster oven, gaming consoles, crockpots, coffee pots, computet, laptops, tabs, Cpap if you should need, I could go on. \n\nBut the simple fact is that the owner of truck should provide a invertor willingly for you and you wife to have a quality of life one should expect. \n\nSo my advice, find another truck to get into and leave your current employer if at all possible. \n\nI know of a few Companies that will pick you up if you should need some help.\n\nYour truck is your home and your employer should  do everything to accommodate you and your wife. \n\nCheers!!\n\"Protect yourself AND Your CDL\"
","text":"Well said!!!","replyToPid":286608}
发表于 2019-12-19 20:04:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I put heavy jumper cables from inverter direct to the battery. \n\nToo thin of wire gets really hot really fast. ","replyToPid":0}
发表于 2019-12-20 04:25:41 来自手机 | 显示全部楼层
","text":"100% agree with this. I was going to say, \" Find a different company\" until I read this right here","replyToPid":286608}
发表于 2019-12-19 15:19:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can get a Duracell DRINV800 inverter with the 12v plug that will run both the TV and XBOX, they are about $100 but that would probably be the way to go","replyToPid":0}
发表于 2019-12-19 15:22:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"that will work but it has to be done wave and your power cord to your 12v source should be heavier then you average 12 power source and you want to add a inline fuse and maybe change your powersource fuse to a higher voltage I'd start with 5v if it holds you good if it blows go up","replyToPid":0}
发表于 2019-12-19 15:24:42 来自手机 | 显示全部楼层
857192 发表于 2019-12-19 07:22:49 that will work but it has to be done wave and your power cord to your 12v source should be heavier then you average 12 power source and you want to add a inline fuse and maybe change your powersource fuse to a higher voltage I'd start with 5v if it holds you good if it blows go up
","text":"sine wave has to be sine wave inverter but really and truly your power source should come from the battery strait from battery","replyToPid":286474}
发表于 2019-12-19 15:51:11 来自手机 | 显示全部楼层
877252 发表于 2019-12-19 07:38:32 Basically your boss is telling y'all to grow up an drive!!!!
","text":"😂, I agree with you but I have to have an inverter not for video games 😂, but for my CPAP, I’d kind of go crazy without one though, I use my microwave quite a bit, and I have a vacuum to clean the graboids off of the floor 😂","replyToPid":286478}
发表于 2019-12-19 21:16:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Glad I don't have that problem my truck came stock with 2 wall outlets where my tv mounts to the wall in the truck. I am 35 and I have kids that play Xbox so I play with them online keeps me connected with the while I am out month at a time!","replyToPid":0}
GMT+8, 2026-3-21 08:38 , Processed in 0.133791 second(s), 24 queries .
