查看: 130|回复: 8
Did you ever overslept while doing your 30 minutes break?
 楼主| 发表于 2019-12-18 04:28:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have done that too many times and now I want to avoid doing it.  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-18 05:35:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yep I stopped at 1 pm to do 30 minutes and woke up at 5:30 pm then said screw it park for the day. I definitely felt rested. Lol. ","replyToPid":0}
发表于 2019-12-18 06:59:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"set an alarm?","replyToPid":0}
发表于 2019-12-18 07:56:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"get your rest, your body will thank you.","replyToPid":0}
发表于 2019-12-18 08:23:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sometimes I take a 1-2 hr nap depending on how hard I've been running the days before. Gives me a really nice boost","replyToPid":0}
发表于 2019-12-18 11:24:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can set a timer on your phone to wake you up after so much time. Also, make sure your mattress is comfy, if it’s not, you wont get good sleep at night. ","replyToPid":0}
发表于 2019-12-18 11:43:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"In the beginning when I first started no, but I would freak out cuz when I went to sleep I would dream I was still driving the truck and then wake up hitting the brakes. So I started running 8-2 splits. Safer alternative And better health","replyToPid":0}
发表于 2019-12-18 11:45:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Of course I was in the sleeper when I would freak out, but all in all. If you are that tired but have the will to keep driving. Do a 2 hour break. You will be happy in the long run. Not as tired and you still can run the same amount of miles. ","replyToPid":0}
发表于 2019-12-18 11:59:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"why do you need to sleep on your 30 minute break? you find a stay at home job if you need to take naps","replyToPid":0}
GMT+8, 2026-2-16 00:45 , Processed in 0.077251 second(s), 24 queries .
