查看: 218|回复: 9
WEIGHT AND SLIDING AXELS
 楼主| 发表于 2019-1-24 21:04:54 来自手机 | 显示全部楼层 |阅读模式
{"text":"If I’m 35,820lbs on my drive, 11,400 on steers and 32,780 on my trailer angels, can that be fixed? My trailer is in the 8th hole. How much weight is changed per hole of I slide my trailer axels up? How much weight per hole of I slide the fifth wheel up?","pics":"[]","canComment":true}
发表于 2022-1-1 03:42:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"We’re do they get these so called truck drivers ","replyToPid":0}
发表于 2021-12-30 14:31:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"3 holes forward should be close ","replyToPid":0}
GMT+8, 2026-3-22 18:31 , Processed in 0.082411 second(s), 24 queries .
