查看: 297|回复: 22
For all those who have worked in Mega Trucking Companies?
 楼主| 发表于 2019-12-18 02:06:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"What are the benefits of working for them instead of working for small-medium trucking companies.  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-18 05:36:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"They get to spend all day every day in EVERYBODY’S way ","replyToPid":0}
发表于 2019-12-19 10:19:04 来自手机 | 显示全部楼层
805928 发表于 2019-12-18 02:25:23 what do they pay for dry van?
","text":"Depends on what you want. I’m making .52 home every other weekend. I would be at .55 if I went otr. ","replyToPid":285321}
发表于 2019-12-18 02:21:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"being known as a number only no one trying to pry into your personal business or to get to know you or anything like that","replyToPid":0}
发表于 2019-12-18 02:14:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Plenty of bull💩 to go around daily.","replyToPid":0}
发表于 2019-12-18 05:18:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"dropyards, terminals,","replyToPid":0}
发表于 2019-12-18 02:13:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depends what companies you consider as mega. Crete and heartland are below mega status yet best paying dry van. ","replyToPid":0}
发表于 2019-12-18 02:57:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"There probably aren’t any benefits over a medium sized company. Over a small company I guess the only benefit would be that they’re more financially stable but that’s not necessarily true either. I suppose there aren’t any benefits instead you should look for a Good company. Talk to the drivers that have been there a while, they’ll give it to you straight.","replyToPid":0}
发表于 2019-12-18 05:08:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"stability,nicer equipment","replyToPid":0}
发表于 2019-12-18 09:25:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"I used to run for CR England and now I run for a small company that only has 40 trucks and is so much better because they can see who likes to run and who doesn't they can see if your worth it or not.","replyToPid":0}
发表于 2019-12-18 10:25:23 来自手机 | 显示全部楼层
542330 发表于 2019-12-17 18:13:38 Depends what companies you consider as mega. Crete and heartland are below mega status yet best paying dry van.
","text":"what do they pay for dry van?","replyToPid":284834}
GMT+8, 2026-4-17 11:37 , Processed in 0.143469 second(s), 25 queries .
