查看: 268|回复: 13
Friend sent me this
 楼主| 发表于 2019-12-18 02:06:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"Told me it is called a terminator air lock. Said it is mandatory in Landstar  ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":960.0,\"name\":\"157/Test%25203_1576605960_1576605960.jpg\",\"url\":\"\",\"width\":720.0}]","canComment":true,"externalShare":false}
发表于 2019-12-19 03:13:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"I used to drill through baby locks like this in less than a minute.","replyToPid":0}
发表于 2019-12-19 00:08:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you can pick the door lock you can pick this POS. All I see is a 2lb brick.","replyToPid":0}
发表于 2019-12-18 23:31:13 来自手机 | 显示全部楼层
877832 发表于 2019-12-18 11:11:37 Had one when I drove for Schneider back in the day, but I imagine a persistent thief wouldn't take long to break into one.
","text":"just back the brakes off 9/16 wrench","replyToPid":285610}
发表于 2019-12-18 02:14:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Heartland has that in every truck. We use them when we go home. ","replyToPid":0}
发表于 2019-12-18 19:11:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Had one when I drove for Schneider back in the day, but I imagine a persistent thief wouldn't take long to break into one.","replyToPid":0}
发表于 2019-12-18 20:38:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"not mandatory at Landstar.","replyToPid":0}
发表于 2019-12-18 23:31:34 来自手机 | 显示全部楼层
235536 发表于 2019-12-18 15:31:13 just back the brakes off 9/16 wrench
","text":"7/16 my bad","replyToPid":285674}
 楼主| 发表于 2019-12-19 00:45:06 来自手机 | 显示全部楼层
542330 发表于 2019-12-17 18:14:25 Heartland has that in every truck. We use them when we go home.
","text":"👍","replyToPid":284838}
 楼主| 发表于 2019-12-19 00:45:21 来自手机 | 显示全部楼层
","text":"True that.","replyToPid":285610}
 楼主| 发表于 2019-12-19 00:45:30 来自手机 | 显示全部楼层
639913 发表于 2019-12-18 12:38:24 not mandatory at Landstar.
","text":"So he lyin?","replyToPid":285618}
GMT+8, 2026-2-16 23:43 , Processed in 0.116436 second(s), 24 queries .
