查看: 71|回复: 3
Humidifier
 楼主| 发表于 2019-12-17 02:48:59 来自手机 | 显示全部楼层 |阅读模式
{"text":"Do anyone here use a humidifier in your truck to combat the drying effect of the bunk heater? If so what brand or specific unit do you use or would using a humidifier in the truck be a bad idea?  ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-12-18 01:11:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"man up a** hole!! you got to take the bad with the good!! gont like that,stay out of trucking","replyToPid":0}
 楼主| 发表于 2019-12-24 01:21:05 来自手机 | 显示全部楼层
766863 发表于 2019-12-17 17:11:27 man up a** hole!! you got to take the bad with the good!! gont like that,stay out of trucking
","text":"😶","replyToPid":284750}
发表于 2019-12-27 13:28:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"They make a small one that plugs into AC converter. My wife brings it when she rides shotgun, but I sleep better with it also. It was a gift she won, but I'm sure if you dig a little you'll find one. Start with Amazon.","replyToPid":0}
GMT+8, 2026-4-17 08:39 , Processed in 0.066627 second(s), 23 queries .
