查看: 458|回复: 15
Will this Wal-Mart stuff make me pass my drug screen and physical
 楼主| 发表于 2019-12-16 12:40:58 来自手机 | 显示全部楼层 |阅读模式
{"text":"Schneider national sent me home from orientation saying I didn't pass","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1632.0,\"name\":\"\",\"url\":\"\",\"width\":1224.0}]","canComment":true,"externalShare":false}
发表于 2019-12-16 20:57:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Tbh if you're into drugs recent enough not to pass, you should be driving a truck to begin with","replyToPid":0}
发表于 2019-12-16 14:05:51 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Didn't pass which? The drug test or physical? If it was the drug test, they will post the result on the national database. You won't be able to get a job using a CDL until go through a DOT approved drug program. Even with that, you will be hard pressed to get hired. If it was the physical, find out why and get with your doctor. Fix the problem and you are good."}
回复 支持 2 反对 2
发表于 2019-12-16 14:11:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"yeah Bob is correct, they test your hair too, if it's the drug test you failed there's no amount of detox to pass you, should have went to another company that only tests urine or laid off the devil's lettuce","replyToPid":0}
发表于 2019-12-16 22:35:15 来自手机 | 显示全部楼层
578388 发表于 2019-12-16 06:05:51 Didn't pass which? The drug test or physical? If it was the drug test, they will post the result on the national database. You won't be able to get a job using a CDL until go through a DOT approved drug program. Even with that, you will be hard pressed to get hired. If it was the physical, find out why and get with your doctor. Fix the problem and you are good.
","text":"Lol none of this is true. Schneider's drug test is so flawed, most drivers don't pass it whether they have ever used drugs or not. They just get hired on elsewhere, or sue Schneider and get hired by Schneider. They don't have to go through any drug rehab to get a different driving job.","replyToPid":283222}
发表于 2019-12-16 22:20:50 来自手机 | 显示全部楼层
What’s a dot approved drug program?
{"replyToPid":283231,"replyTo":"
867408 发表于 2019-12-16 06:22:08 What’s a dot approved drug program?
","text":"No idea. The regulations talk about it. I know the bigger companies have a drug rehab setup of some kind. I have not dealt with it other than having students freaked out about drug testing."}
发表于 2019-12-17 00:06:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yet, guys sit there sleeper and get drunk every evening.. I know for a fact, booze is way more detrimental to health, and daily performance than weed.. I would rather a guy do drugs on his off time,than drink every night at the truck stop. Just because it’s legal, doesn’t make it better! ","replyToPid":0}
发表于 2019-12-16 22:32:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Go drive for a flip camel jockey, they hire ya without a CDL","replyToPid":0}
发表于 2019-12-20 21:28:34 来自手机 | 显示全部楼层
854041 发表于 2019-12-16 14:35:15 Lol none of this is true. Schneider's drug test is so flawed, most drivers don't pass it whether they have ever used drugs or not. They just get hired on elsewhere, or sue Schneider and get hired by Schneider. They don't have to go through any drug rehab to get a different driving job.
","text":"Facts I've failed their drug test twice and ain't ever done a drug in my life and never had to go through no dot rehab haha these knuckleheads make up anything.","replyToPid":283380}
发表于 2019-12-17 04:29:58 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Every time you are hired to a trucking job, you are asked if you failed a drug test for a CDL related job. You used to be able to lie and get away with it. Now they have a nationwide database of test results. Worse, say you lie. An accident while having lied about something like that turns misdemeanors into felonies. The lawyers will always check. There are too many drivers who have totalled their lives by doing things like lying on job applications. These days, if you lose a civil case where you committed a crime, you can't bankrupt out from under the debt. One truck accident could load you up with a $250000 or more of debt that is bearing interest. It isn't a game I want to play."}
发表于 2019-12-16 14:31:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"you're kinda screwed basically. 😕","replyToPid":0}
发表于 2019-12-16 14:22:08 来自手机 | 显示全部楼层
","text":"What’s a dot approved drug program?","replyToPid":283222}
发表于 2019-12-16 21:26:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"didn't you get fired from schneider a while back?  could have sworn you said that.","replyToPid":0}
GMT+8, 2026-4-18 17:25 , Processed in 0.123038 second(s), 24 queries .
