查看: 154|回复: 9
My tires look really low on air. Should I waste time and put air in or keep driving? I dont have time.
 楼主| 发表于 2019-12-16 05:21:30 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-12-16 06:29:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"R u stupid???","replyToPid":0}
发表于 2019-12-16 05:43:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"if the air is too low you're destroying your side walls everytime the rubber heats up and cools which could lead to blowout and if it's a steer tire then God bless you","replyToPid":0}
发表于 2019-12-16 05:49:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Proper air pressure is crucial to safety. Your safety (and other’s) should not be neglected. ","replyToPid":0}
发表于 2019-12-16 08:42:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"It only goes flat on the bottom ","replyToPid":0}
发表于 2019-12-16 13:57:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"loves, $10 for tractor and trailer, could save you hours instead of roadside.","replyToPid":0}
发表于 2019-12-16 05:39:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Doesn’t take long to put air maybe 5 minutes but your call it may bite you later down the road  ","replyToPid":0}
发表于 2019-12-16 06:39:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keep on rollin’ playa. It’s just a recommended psi, don’t sweat that sh1t ","replyToPid":0}
发表于 2019-12-16 08:13:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keep going! I believe in you!","replyToPid":0}
发表于 2019-12-16 08:26:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"(It's not like if the tire blows, u scare the passing 4-wheeler into panic, they wreck, & most people will assume you're responsible for their accident.)","replyToPid":0}
GMT+8, 2026-2-16 17:16 , Processed in 0.067605 second(s), 24 queries .
